09-20-2019, 10:45 PM | #1 |
Rep 86
Battery Charge or Replace?
Good evening fellow enthusiasts,
I've been noticing that my 2015 M4 is taking a bit longer to start up for the past two days. I imagine that it is a battery issue. A little history on the car is that I bought it in March 2019 with 6000 miles and its now at 9200. The car sits for a couple days at a time but I've been driving it frequently within the past two weeks. The car is out of warranty. I also do have a radar detector that I have tapped into the mirror that is plugged in all the time. After looking at the cost of a new battery, I was wondering if a trickle charger (specifically the CTEK referenced in the forums) would do the trick or whether I'd have to buy a new battery. I was hoping that it would last longer but I understand that driving a car sporadically and having a radar detector could shorten it. I am unfamiliar with the CTEK trickle charger as well. If this is a solution, would anyone mind explaining it to me and how I can use it? Thank you very much for your time and consideration Nick |
09-21-2019, 07:49 PM | #2 |
Rep 1,105
Could be anything: battery too low voltage, bad ground cable, bad starter motor, loose cables to the starter, vapor lock, ... . The trick obviously is to pinpoint which one it is.
Check grounding cable: https://www.realoem.com/bmw/enUS/sho...diagId=12_2092 Is it hot where you live? What is the voltage of the battery? Does it happen everytime? Last edited by G4BR13L; 09-21-2019 at 08:04 PM.. |
09-21-2019, 10:49 PM | #3 | |
Rep 86
09-21-2019, 11:34 PM | #4 |
Racecar Driver
1313
Rep 1,989
Drives: BMW M4
I have a feeling it's because you're not driving it enough to fully recharge your battery, therefore it's a weak battery. Heat kills batteries.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
09-22-2019, 04:46 PM | #5 |
Rep 86
Would taking it for a long drive help out? Also would the CTEK battery charger charge the battery? I'm planning on getting one since when I normally drive the car its days between sessions.
09-22-2019, 05:54 PM | #6 |
Racecar Driver
1313
Rep 1,989
Drives: BMW M4
You can try taking it on an hour drive without turning the car off and see if it helps. I'm not familiar with the CTEK battery charger but if you're looking to get a battery tender, make sure it works with the Lithium battery in the F8X. You can't use a normal lead acid battery tender.
N1rve
09-22-2019, 06:16 PM | #7 | |
Rep 86
09-23-2019, 02:29 AM | #8 | ||
Rep 3,729
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
09-23-2019, 09:51 PM | #9 |
SCKOMS
89
Rep 99
09-24-2019, 09:12 PM | #10 |
Rep 490
Edit: As a sanity check, the battery tender in the original amazon link did not specifically say it is meant for Lithium flavored batteries. Thanks SCKOMS for updating. New link does indicate Lithium battery compatibility.
CTEK is recommended in every thread about this. Last edited by agentrnge; 09-25-2019 at 08:57 AM.. |
09-24-2019, 11:26 PM | #11 |
SCKOMS
89
Rep 99
09-25-2019, 06:42 AM | #12 |
Rep 86
