09-28-2019, 08:57 AM | #1 |
Rep 12,654
AutoTalent | Active Autowerke Filter+Pipe kit+Intercooler for Bmw E82 135i 2007-2013
Active Autowerke Green Filter Cleaning Kit To order please visit our website by clicking HERE Keep your Active Autowerke / Green High Performance Air Filter in perfect condition with the specially formulated Recharge Oil (8 oz.) and Cleaner Spray (12 oz.). Both are sold together as a complete Cleaning KIT. The recharge oil is designed to trap the smallest of dirt particles ensuring your engine breathes only the cleanest of air. and o not damage any vehicle sensors and ensure that your Green Filter can trap before they reach your engine. It is recommend that you visually inspect your Active Autowerke Green Air Filter at every oil change. As a general rule, this filter should be cleaned at every 30,000 miles; however, this interval can be greatly influenced by your environment and driving conditions. In dusty areas, you may need to clean the filter more often. Green High Performance Air Filters comes pre-treated with a specially formulated dirt-trapping oil. It is a proprietary lightweight, synthetic filter oil designed specifically NOT TO damage any vehicle sensors. This oil creates a positive (+) magnetic charge, with the filter's stainless steel mesh. This positive charge attracts the negatively (-) charged dust particles entering the filter, causing them to cling to the steel mesh and allowing the cotton to remain clear for maximum air flow. Features keep Air Filter in perfect condition Remove Dirt Keep vehicle sensors Safe Easy Cleaning Process Cotton Filtration ----------------------------------------------------- Active Autowerke Aluminum Charge Pipe Kit To order please visit our website by clicking HERE The Active Autowerke N55 Charge Pipe has a proper provision for this specific application. A boss with two separate ports are provided upstream where the injected mix of water/methanol can properly atomize before entering the engine. The thread depths for the water/methanol nozzles are also checked to allow for a proper spray pattern without hitting the inside walls of the threaded holes. The Active Autowerke N55 Charge Pipe is a designated product designed from inception to cure and eliminate this problem on your BMW. Constructed from all aluminum makes this charge pipe almost indestructible. The connection to the throttle body is a CNC machined part to duplicate the factory fit as well making a tight, reliable seal. The BMW N55 engine does not utilize external diverter valves like it's N54 predecessor. Rather, the BMW N55 has diverter valves that are built inside the engine turbo compressor housings and no in the charge pipe. As such, there are no provisions to add larger BOVs. Features Specific design to correct a problem Consistent 3.00" tubing for increased performance Increase throttle response and decrease throttle lag CNC machined throttle housing for a poper seal Retains factory BMW O-Ring seal Provision of raised boss for 2 Water/Methanol nozzles Black powder coated for that OEM look ---------------------------------------------------- Active Autowerke Intercooler Kit To order silver kit please visit our website by clicking HERE To order black kit please visit our website by clicking HERE The Active Autowerke BMW 135i intercooler is the best performing bolt-on performance intercooler. Simply by bolting on this intercooler on a stock car, you can expect over 10 wheel horsepower gains due to the revised efficiency, or even more with additional performance modifications like our Active Autowerke BMW 135i Downpipe. This intercooler is created to handle more internal air flows than its stock counterpart, and will not heat soak as readily like the BMW factory unit. Designed from inception, this BMW 135i intercooler has the largest swept area that could possibly be fitted within the narrow space confines that the BMW factory allowed. Simply put, this BMW intercooler will perform and deliver consistent, reliable power run after run without power robbing heat soak. Some minor cutting is required. This Active Autowerke BMW intercooler features the industry standard of a bar and plate core design with seamless cast end tanks that utilize the OEM quick connectors for the easiest install possible. Proper placement of heavy duty mounting tabs ensure for a good fitment. This Intercooler is Designed specifically for the BMW E8X 135i With the addition of CNC machined outlets the installation of our sport intercooler is easier than ever! Large but compact, it delivers the performance reliably and consistently as intended with the added features to be reversible if the need arises. Features Industry standard bar and plate core design for that rugged construction Delivers substantially more internal airflow than the factory BMW unit No heat soak measured on street application Delivers an increase in BMW performance consistently Cast end tanks with sturdy mounting bosses CNC Machined outlets to accept the OEM charge pipe connections Detailed CD instructions featuring mostly pictures with less text Easy to install to the factory set-up with the benefits of reversibility if needed How to Place Your Order: Phone Domestic: (855) 973-2757 X 104 Phone International: (310) 231-7800 X 104 E-mail: online@autotalent.com Website: www.AutoTalent.com Payment: Installations: Feel free to visit us at our facility in Los Angeles, CA. We install everything we sell. 19143 S. Hamilton Ave Gardena, CA 90248 Shipping: All orders are shipped via FedEx, UPS, USPS and Pilot. International, Hawaii and Alaska customers: Please contact us for the best quote possible. Hours of Operation: Monday through Friday: 10AM-7PM Pacific Time Saturday: By appointment only |
