11-04-2019, 02:03 PM | #1 |
Rep 684
E93 Stalling after fuel up
I've read a few post with this problem and have decided to replace the Fuel Tank Breather Valve, however, my problem doesn't exactly match what others have experienced though.
The car will do a nice gentle engine stall right after filling up only about every 5th fill up. The RPM's on occasion will also jump up and down a few hundred while at a stop with the engine running and warm. Now this weekend I did about 100 or more highway miles, then i pulled off and did some city driving. The engine would either stall while at a stoplight or the RPMS would jump around inconsistently under 1000. I didn't get any codes and the gas cap is and has always been secure. Is replacing the Fuel tank breather valve a good starting point or should I be looking elsewhere? I appreciate your advice/input -Mark |
11-04-2019, 02:21 PM | #2 |
Rep 1,732
It's a fairly easy DIY and place to start - I did mine a few months ago. Previous owner mentioned having similar symptoms, I never experienced any, but I had the part and was doing spark plugs so I figured might as well do the fuel tank breather valve. No issues at all.
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190 |
LakeSurfer821.00 |
11-04-2019, 02:22 PM | #3 |
Rep 4,107
Sounds like my fuel tank breather valve symptoms. Would not stall/varying RPM after every fill up, was sporadic. After a while it happened very occasionally as the tank neared empty before filling. It's an inexpensive fix so worth giving it a shot first to see if that solves the issue.
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 |
LakeSurfer821.00 |
