11-10-2019, 11:44 PM | #1 |
Rep 43
Removing battery for winter
My car will be in storage for the winter but won’t have an electrical source to hook it to a battery tender. Can I remove the battery to maintain it for an extended period of time and not have to re-register it or cause any issues when I reinstall it come Spring?
11-11-2019, 04:00 AM | #2 |
Rep 1,300
Yes, you can remove the battery and don’t need to re-register. No issues. I did that the first year I had my car as I live in an apartment, with no outlet near my spot for a charger. The subsequent years I just unhooked the negative terminal and left the battery in the car. MAKE SURE you folder the back seat first, regardless you take the battery out or unhook the negative. The trunk release won’t work without the battery. You’ll need to unlock the door with the key and crawl into the back and pull the trunk release cable. Last winter I parked my car at my parent’s house and kept it in a charger so I don’t have to deal with all that hassle.
Also don’t start up the car every few weeks during storage in the winter. You’ll introduce moisture in oil. If you do start it, make sure you go for a long drive and get the engine up to temperature for awhile. |
11-13-2019, 04:56 AM | #4 |
Rep 115
I’ll be doing this as well for the winter as I don’t have the luxury of power source for a trickle charger...don’t mean to TJ but how long can we have the car sit for? If we were to say be away for a couple of weeks parked outdoors, still consider unhooking the neg terminal for this duration?
11-13-2019, 09:48 AM | #5 |
Rep 2,145
Drives: 2011 E92 M3
If it is parked outside, there are solar options that will trickle charge your battery.
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
kyrix1st2373.50 |
11-13-2019, 09:57 AM | #6 |
Rep 460
Mine is in a garage with lighting too dim to use as a power source and no outlets in sight.
So far I just left it parked, doors locked with the battery connected. I was wondering about losing the calibration of the steering angle sensor or other sensors? Is this the case with extended battery disconnects? |
11-13-2019, 10:03 AM | #7 | |
///M Powered for Life
11503
Rep 10,335
I've gotten through 5 months of having the car sit outside without issues starting it back up in Spring |
Bartledoo2691.50 |
11-13-2019, 10:14 AM | #9 | |
11503
Rep 10,335
Now I run a extension cord and charge it every 3 months |
11-13-2019, 11:02 AM | #10 | ||
Rep 6,638
11-13-2019, 03:42 PM | #11 |
Rep 115
Sorry I wasn’t being specific, I meant that can I leave the car parked outdoors without trickle charging it for a couple weeks if I had to go on a trip or what not. I don’t have a power outlet to trickle the battery for this coming winter also so I’m going ahead to what was suggested to op for just disconnecting the negative terminal of the battery
SYT_Shadow11503.00 |
11-13-2019, 04:00 PM | #12 | |
Rep 1,300
11-14-2019, 08:15 AM | #13 |
Rep 1,178
It is such a mistake to not drive the S65 in the winter. It gives me significantly more power from the cold air, more than all the typical slap on mods. In fact the difference is so great that i always think about selling my e92 m3 in the summer but change my mind the next winter. As a naturally aspirated engine without direct injection it hates warm air. In fact i consider the e92 m3 a winter only sport car. Could not understand how people in Cali or Florida live with it. It must be vanity but i need the performance to like a sports car. I guess if you ever experience it in cold german temperature you will hate it in the summer.
InnerBlueSkies1092.50 |
11-16-2019, 07:06 AM | #14 |
Save the manuals!
6032
Rep 6,753
If you can't connect a trickle charger to it, simply disconnect the negative terminal and you're golden. I've never removed the battery itself while winter storing cars for 5-6 months for the last 12 years.
Be sure to fold down the rear seats or leave something blocking the trunk from fully locking in order to have access for reconnection. Never had an issue. You won't lose any calibrations or sensor issues, lol.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
11-17-2019, 02:02 AM | #15 | |
Rep 7,130
11-17-2019, 02:04 AM | #16 | |
Rep 7,130
Rajmun340413.00 |
11-19-2019, 05:49 PM | #17 | |
Rep 1,178
I can only imagine if the S65 was direct injection NA instead of port, it would probably give an extra 30-40 HP. i think the S85/S65 would have inspired another generation of bespoke engines in 2013, with FI added (it also reduces consumption significantly), but the 2009 financial crisis hit auto manufacturers hard and the M division might have had to abandon exotic bespoke designs and use the same weenie 3.0L engine block that equips nearly all bmw's including the F8x M4/3 + added tuned mitsubishi turbo on it. The difference in workload was definitively much reduced from the S85/S65 to the S55 engine design at the M division. A total change of philosophy and budget. It's also possible they lost the M division engineers who designed these bespoke engines. |
