11-18-2019, 05:16 AM | #1 |
Rep 942
Remove front strut from knuckle
Part way through fitting ACS RS kit (KW v3).
Front end is all stripped down, N/S/F strut is poking out of the arch, but I can't get the bloody thing out of the knuckle! Bolt is obviously out, I've opened it up with a pry bar, but it just will not move. What am I doing wrong? TIA!
2016 F80 M3
11-18-2019, 09:19 AM | #2 |
Rep 6,733
Whack it with a mallet and pull/twist. There’s a guide pin/groove so it won’t twist fully but you just need to release from it being seized up
11-18-2019, 10:10 AM | #3 |
Rep 1,562
And spray it down with some WD-40 or other lubricant and let sit for a few minutes. Make sure you clean all of the debris and dirt FIRST before spraying it!
11-18-2019, 10:31 AM | #4 |
Rep 1,164
Instead of a pry bar, i used the following and the strut came out effortlessly after a few whacks with the mallet. Didn't need to juggle keeping pry bar pressure on the knuckle and whacking the strut with a mallet. The tool is inserted and keeps the knuckle separated.
Strut Separator: https://amzn.to/33p0uFu |
11-18-2019, 01:20 PM | #6 |
Rep 942
Cheers all, I'd used loads of WD40, ended up giving it a tap from the side and it slipped straight out.
Both sides were really awkward!
2016 F80 M3
