11-25-2019, 07:52 AM | #1 |
Rep 264
Will long warm up period kill my battery?
I recently sent my car to a local shop to do full inspection. They notice my battery is about to change. I quickly think about will long idle time kill my battery? Every morning I start up the car before breakfast, the car will idle 10~15 minutes before I drive it, I did turn the lights and radio off, but will this still be one of the fact to cost my battery goes bad?
11-25-2019, 07:57 AM | #2 |
F15 daddymobile
2353
Rep 3,519
How far is your commute? I would think it would be fine unless your battery is already 10years old
11-25-2019, 07:59 AM | #3 | |
Rep 1,389
11-25-2019, 08:03 AM | #4 |
Rep 264
11-25-2019, 08:04 AM | #5 | ||
Rep 264
11-25-2019, 08:09 AM | #6 | |||
Rep 1,389
JMH109934.50 Drifter2090912.50 |
11-25-2019, 09:36 AM | #8 | ||||
Rep 935
Drives: E90 M3
I agree with the manual and common knowledge that a car doesn't need to idle but for my sanity I'd rather wait and make sure oil is to temp, or maybe cut down to 1-2 minutes. I'm doing an oil change this weekend, I'll ask Blackstone if they see anything in the oil that can be idle-induced |
11-25-2019, 09:56 AM | #9 |
Rep 801
Also, think about how many extra hours of run time you are adding to that motor.
2011.75 E90 M3 | 2006 GMC Sierra LBZ | 2004 X5 3.0i 6MT | 1995 M3 S50B32 | 1990 325is | 1989 M3 S54B32
Hers: 1996 911 Turbo | 1989 325iX |
11-25-2019, 10:54 AM | #11 |
Rep 71
Once your car's engine has started, the alternator is actively charging the battery, idling or driving don't matter from a battery standpoint.
As for the warm-up thing, here's a decent article with a quality source. We're fortunate that our cars have oil temp gauges as default: https://jalopnik.com/nascar-engine-e...our-1832245942 |
11-25-2019, 10:56 AM | #12 |
Rep 10,666
I will wait as long as a minute. The motor runs smoother. Less jerkiness. Often I don’t really have time and just go. I always drive gently and under 3000 rpm until the motor has warmed up.
No worries on the battery from idling. Battery is probably tired. If so it may not start the car on a very cold day. |
11-25-2019, 11:04 AM | #13 | |
Rep 935
Drives: E90 M3
11-25-2019, 11:09 AM | #14 |
Rep 71
Yeah, there's an overabundance of info on the topic, that one seems to cover the bases for actual humans driving their street cars, even ones with race-oriented engines. Short of going full F1 and circulating preheated coolant through the engine's cooling system so the block is up to full temperature even prior to startup...
11-25-2019, 12:16 PM | #15 |
Rep 2,824
As others have said, the idling is not killing your battery, but is not good for the engine either. If your commute is long enough get the fluids up to temp, just drive it moderately until it's warm.
wfdeacon881105.00 |
11-25-2019, 01:29 PM | #16 | |
Rep 1,389
11-25-2019, 01:56 PM | #17 |
Rep 1,389
Drives: 2012 E92 M3
I thought on these cars the alternator is only engaged when you decelerate and not while idling?
12 M3 Interlagos Blue/Black
18 Jeep Grand Cherokee (Yeah, it's got a HEMI) 21 X3 Silver/Black(Wife's) 06 330i Monaco Blue/Black (retired) 02 X5 3.0 Topaz Blue/Black (retired) |
11-25-2019, 02:12 PM | #18 | |
Rep 7,129
Ps. Btw using Carly one can also see a proper and typical alternator current of 30-40A at all times, must go somewhere. |
11-27-2019, 05:24 PM | #19 |
Lord Scrip
1823
Rep 3,018
Drives: 2011 M3 Coupe
Always let it idle for 2-3 then drive moderately until up to temp. I could give two shits what the manual says about driving immediately. Especially when terms like "lifetime fluid" are present in it as well.
11-27-2019, 06:05 PM | #20 |
Rep 1,389
I think this is probably the best way to do it... just a couple minutes to let the engine materials get up in temp, and then easy driving until oil gets to operating temp.
11-27-2019, 07:45 PM | #21 | |
Lord Scrip
1823
Rep 3,018
wfdeacon881105.00 |
11-27-2019, 09:42 PM | #22 | |
Rep 1,178
