11-25-2019, 07:58 PM | #1 |
Rep 16
First time coding and one strange thing happended
First of all, everything went smooth, and I ended up with the following changes in about 10 min.
M Start-up Animation Side mirror fold with comfort access Video in Motion Close tailgate with remote AC remember last setting. I used Veepeak OBDCheck BLE since it was in the list of recommended adapters. Bimmercode website now warn not to use adapters not listed on their website. I coded one change at a time and all went through without an issue. The strange thing is that I NEVER changed the AC remember last setting. When I tried to change that setting I saw it marked Active already. So I tested it by starting the car and etc. and sure enough it remembers last setting. My theory is that this setting was already defaulted to Active in Bimmercode and got coded along with my first change?? I also tried coding with both engine on and off without an issue. And lastly, Video in Motion requires second step where you have to make sure to hold the control button up until it tells you that it's completed. I did M animation coding after that and it reset this second part of VIM change and made me go through that again. These two settings must same common code in a way. For those of you who changed angel I brightness, do you know what the factory value is? It is listed as unassigned. |
11-25-2019, 09:36 PM | #2 |
Rep 2,523
