12-06-2019, 08:57 AM | #1 |
Rep 3,625
Oil Drain Plug Spinning - Stripped Oil Pan
Last night wasn't a lot of fun. What was supposed to be a routine oil change turned into a major pain in the ass. When I was attempting to remove the drain plug, the bolt would just spin and place and would not come out. I kept working on it and finally got it out.
I wasn't sure if the bolt was going to be stripped or the oil pan so I ran to Auto Zone first thing this morning and they didn't have the right size bolt. I then ran around the corner to a repair shop that advertises that they repair BMW's to see if they would have one on hand that they would sell. A black F15 X5 was parked out front which happened to be the owners. I told him what was happening and he said the exact same thing happened to him and it turned out that there was a small crack in his oil pan. He said BMW is aware of this issue. He did not have the bolt on hand so I went to my local BMW dealership to get one. I got home, started screwing in the bolt and everything was going great. I grabbed the torque wrench and it just wouldn't tighten. I do not have any oil leaks and called my independent mechanic to setup an appointment for Tuesday. Anyone else with experience with this problem? |
12-06-2019, 05:28 PM | #2 |
Rep 2,995
Which engine you have? Steel or aluminum pan? You may need to retap the hole. And why you using a torque wrench? A plug just needs to be snug. I don't understand those who feel the need to crank the plug on tight. It's not holding anything!
12-06-2019, 07:10 PM | #3 |
Rep 3,625
N55 and I grabbed a torque wrench to tighten to the spec BMW recommends which isn't very tight.
12-06-2019, 08:27 PM | #4 |
Rep 2,995
11-07-2022, 02:05 PM | #5 |
Rep 699
Drives: 2011 BMW M3
Same thing happended to my F15 35i yesterday, that was my 3rd oil change by myself, when I was attempting to remove the drain plug, the bolt just spin and would not come out. I use a plier to hold and give it a down force and turned it as the same time, when the bolt hold a firm postion (kind of hard to turn), I immediately change to my 3/4 drive with 17mm and turn it carefully and then finally got it out.
After the oil come out, I use small tweezer to check the thread and some steel debris dropped and I also find a lot of debris in oil drain container. It seems that my oil pan thread was stripped and checked the drain plug bolt and it seems normal. I bought another M12-1.5 drain plug from Advanced Auto Parts and carefully screwing in the bolt and take extra cautions and not too tight and the bolt seems holding the positon. ( but I thought if I gave more torque, it will stripe again). And filled into 0w40 6.5quarts and changed the oil filter as well, take the car out for a drive and test the oil level it was normal. I will check it from time to time to see if there is any oil leaking and if it can hold until to next oil change, I may give oil pan a compelete check at the shop or may change the oil pan (that is $$$).
2016 F15 X5 xDrive 35i Space Grey M-Sport - BM3 Tune/ER charger pipe/afe power dry panel filter.
2011 E92 M3 DCT MW - AA intake/Akrapovic slip on/Ohlins R&T/Stoptech ST60 and ST40/Underdrive Pulleys/Antigravity H6 40ah/Alpine Tune |
11-07-2022, 09:45 PM | #6 | |
Rep 97
2018 X5 35i
11-08-2022, 12:27 AM | #7 |
Rep 699
Drives: 2011 BMW M3
Never. I am the original owner of the car. First 4 years serviced at the dealership and recent 2 years I did by myself, I think it was not tightened too much but it may be caused by a bad angle when screwed in last time? I don't really remember there is noticable bad angle.
11-08-2022, 07:26 AM | #8 |
Rep 666
E90325M - Noticed that you have the quick jacks w/extension. Is that the 7000TL? Also, are you using anything besides the urethane blocks and did you have any issues aligning each side between the jack points?
I found I was short on both front and rear mounts and contact was made on the last 3rd of the block which was less than ideal. Ended up buying additional aluminum jackpads to increase contact points. Curious what you used. |
11-08-2022, 10:06 AM | #9 | |
Rep 7,164
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
'06 C55 AMG (sold) ‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe '14 X5 50i (wife’s now) |
11-08-2022, 01:04 PM | #10 |
Rep 243
I went thru this on my last F15, I bought it CPO and the first oil change change I did I realized it had been stripped, all the oil changes prior were done by bmw as included maintenance. So dont rule out BMW techs over tightening it.
Anyway I ended up re-tapping it to a M14-1.50 thread and installed a valvomax drain valve so it never happens again. |
E90325M475.00 |
11-08-2022, 10:34 PM | #12 | |
Rep 699
Drives: 2011 BMW M3
11-08-2022, 10:41 PM | #13 |
Rep 699
Drives: 2011 BMW M3
What is the helicoil fix? do you have any details?
11-09-2022, 08:01 AM | #14 | |
Rep 666
Damn impressive to watch the QuickJack deadlift the X5, but damn are they heavy to move around. |
E90325M475.00 Seattlesquash912.50 |
11-09-2022, 04:28 PM | #15 |
Rep 140
https://static.nhtsa.gov/odi/tsbs/20...61547-9999.pdf
Here's a repair bulletin, downside is you will need to buy a bunch of crush washers specific to the oversized bolt. The one with the oil filter will not fit |
E90325M475.00 |
11-09-2022, 06:00 PM | #16 |
Rep 138
Happened to me and thought the previous shop stripped it. BMW was doing this oil change now. They have a BMW retaining kit for this purpose supposedly. Sounds like it's common enough that they have kits.
On my old n54, I've had shops tighten it enough where I could barely get the plug off. I wonder 8f the pan changed to a thinner material or something |
11-10-2022, 10:00 AM | #17 |
Rep 666
I generally change oil through the dipstick (diesel), but given the pan/drain bolt is a fail point, I'm thinking of going with this setup.
Stahlbus Oil Drain quick connect |
E90325M475.00 |
11-10-2022, 01:38 PM | #18 | |
Rep 699
Drives: 2011 BMW M3
11-10-2022, 08:34 PM | #19 |
Rep 1,037
11-10-2022, 09:12 PM | #20 | |
Rep 699
Drives: 2011 BMW M3
You mean DIY to replace it? I don't know how hard of this job.
11-10-2022, 09:34 PM | #21 |
Cattlecar
44
Rep 141
Actually Time-Sert and other threaded insert repairs are better. Heli-coils are square cross-section wire rolled into a cylinder shape. They work fine for head bolts or any repair where the bolt or stud is screwed in and left there. A drain plug and spark plugs will be removed and re-installed several times and the Heli-coil may walk in or come out with the plug. The threaded insert style has a beveled flange end and you drill, tap, and run a countersink tool in that allows the insert to go below the face and have a stop. Thread locking compound on outside, installing until stopped, and then a finisher tap/expander is run in. All of that assures it is going to stay put and removing and installing the drain plug will not be a problem.
Seattlesquash912.50 1004ron28.00 |
11-10-2022, 09:49 PM | #22 | |
Rep 1,037
I just would be cautions about doing any sort of tapping/inserts in the of chance any metal shavings are left in the pan. |
