BMW M3 Forum (E90 E92)
Mporium BMW
      12-19-2019, 08:55 AM   #1
Shiza
Shiza's Avatar
1195
Drives: M3, X5, Ram 2500, Wrangler
Öhlins adjustment question
Stupid question for those who have Öhlins. In the rear, I have the preload on the spring set to the 37mm that the instructions state is recommended. I'm trying to adjust my ride height and I've lowered it as much as the shock/coil will go with no difference in the ride height. Do I need to adjust preload as well to lower the height?
      12-19-2019, 10:22 AM   #2
christoepurrr
Drives: BMW M3
Yes, you would need to adjust the preload of the spring on the rears. Setting the preload of the spring to 37mm as per Öhlins instructions lowers the car 20mm from factory ride height.
Shiza1194.50
      12-20-2019, 10:06 AM   #3
M_Chronos
M_Chronos's Avatar
112
Drives: BMW M3
Are you guys referring to the perch adjustment as preload?
      12-22-2019, 06:37 PM   #4
Shiza
Shiza's Avatar
1195
Yeah I think so
      12-22-2019, 06:38 PM   #5
Shiza
Shiza's Avatar
1195
Another stupid question.... is this the correct position for the strut and endlink? When I turn the wheel even with my hands I can see the endlink flex a bit.
      12-23-2019, 11:48 AM   #6
M_Chronos
M_Chronos's Avatar
112
Drives: BMW M3
The rear is just an adjustable perch, it doesn't preload anything like the front does despite Ohlins referring to it as the preload adjuster in the manual.
That is what sets your height, if it no longer has an impact on height then there is something else up. Check the shock height per the specs in that manual.
      12-23-2019, 06:44 PM   #7
cannga
Drives: BMW M3 & Porsche 997 Turbo
This is picture of my install - hope it helps.
Regards,
Can
2008 Porsche 997 Turbo - Manual with Bilstein Damptronic Coilover Discussion Here, Custom Tuned ECU, Cargraphic Exhaust
2011.75 BMW M3 - DCT with Ohlins Coilover - Ohlins Settings & Impression Here
Shiza1194.50
m3post
