12-20-2019, 07:44 PM | #1 |
Rep 2
Drives: BMW e93, Mercedes GL450
08 Rod bearing pics
08, e93, 99000 miles exactly. Just picked the car up and did a preventative replacement all dealer records and no record of it being done. 1 to 8 in order top and bottom.
12-21-2019, 09:45 AM | #3 |
Rep 258
Good call. Those look kind of unhappy. I did mine when I bought the car and they looked way better than those. I think it's just a must-do on these cars.
12-31-2019, 02:10 PM | #8 |
Rep 10,668
Failure is bearing that has spun and/or become welded to crank. Many of the picture of removed bearings show some heavily worn bearings or bearings that are failing.
12-31-2019, 02:24 PM | #9 |
Rep 3,654
These are some of the worst I've seen - at least the ones that have chipping. I saw these in person, I had my car at the same shop/same time for RB replacement.
https://www.m3post.com/forums/showthread.php?t=1352151 |
12-31-2019, 03:40 PM | #10 | |
Rep 6,638
12-31-2019, 06:08 PM | #12 | ||
Rep 2,145
Drives: 2011 E92 M3
All of this happens without much warning over a very short period of time. Good times...
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
01-01-2020, 06:11 AM | #13 | |
Rep 3,361
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
01-01-2020, 02:30 PM | #14 | ||
Rep 6,638
01-01-2020, 10:30 PM | #15 | |||
Rep 2,145
Drives: 2011 E92 M3
When a bearing is too tight, the hydrodynamic wedge does not properly protect against physical contact when loaded. This damages the Babbitt over time. If it gets bad enough, then there will be too much metal to metal contact and this will cause a bearing to spin due to excess friction. The wear we are talking about is measured in thousandths of inches. And, unfortunately, bearings do not wear evenly and self-clearance. Hydrodynamic bearings should outlast the chassis of the car. They should not need to be replaced in the normal service life of the vehicle if properly designed. The S65 is a nice engine, but it uses the same rotating assembly fundamentals as everyone else. It is not special. And at ~103 HP/L, it is not pushing the specific output envelope. Yes, it revs pretty high. But so do a lot of other cars. Cheers,
