12-31-2019, 03:56 PM | #1 |
Rep 368
detailing question
my '09 m3's interior is starting to show it's age and I want to freshen it up.
Strategy 1. detail interior 2. dye for leather 3. dye for plastic Question on detailing interior. I'd prefer to do it myself but my current strategy of using qtips and alcohol doesn't lasts a few hours and then the vents get dirty again. Any way to keep this stuff clean? |
12-31-2019, 04:03 PM | #3 |
Stop the hate, get a V8
3853
Rep 8,625
Plastic dye? You're better off replacing those parts outright. Tinted windows and routine application of a UV-protectant on those plastics will greatly slow down their fading. I would also highly recommend against doing leather dye yourself -- very easy to screw it up. Find a reputable automobile interior replace (e.g. the places that do convertible tops or upholstery) and let them fix things. Many of them actually have mobile services.
Go buy a pack of small paintbrushes for dusting in the vents. You can also get those air duster cans used for computers and keyboards for any other hard-to-reach spots.
Past: 2011.5 M3 sedan ZCP |
Drifter2090912.50 |
12-31-2019, 04:11 PM | #4 |
Rep 526
I would recommend a good interior cleaner over an APC in any situation and especially with the condition of some of the plastics in your pictures (peeling finish etc.).
I've had consistently top notch results with 1z Cockpit Premium and a Swissvax or DD brush over the course of my detailing career. Simply spray the cleaner on a small area, lightly agitate with the brush, and then dry the area with a clean microfiber cloth. https://www.detailersdomain.com/prod...ockpit-premium https://www.detailersdomain.com/coll...ailing-brushes You don't have to shop at DD but I've been buying from Phil for over 10 years with literally zero problems. Like Dparm wrote, don't fool with plastic dyes - the BMW's interior plastics have rubberized coatings to soften the look and feel. They can't be dyed to be repaired. There are several vendors that sell color matched leather dyes but I would recommend Colourlock's system for good results that are achievable by a novice if you want to do it yourself. https://www.colourlock.com/bmw_leath...a?___store=usa |
12-31-2019, 04:18 PM | #6 |
mTekMods
2161
Rep 2,912
You need a new center console trim that’s for sure
Drifter2090912.50 |
12-31-2019, 04:28 PM | #7 |
Rep 6,638
12-31-2019, 04:48 PM | #8 | |
Rep 18
I recently switched to P&S interior cleaner with a small detailing brush/microfibers and it works like a charm. |
12-31-2019, 06:43 PM | #9 |
Rep 526
It's true that Cockpit Premium doesn't smell as good as it used to several years ago but it still cleans extremely well.
I'm a huge fan of P&S Bead Maker and Brake Buster. I'm sure their interior cleaner is good as well. |
12-31-2019, 07:00 PM | #10 | |
Rep 967
P&S is great but it just doesn't clean well imo |
12-31-2019, 07:22 PM | #11 |
Rep 526
Everyone is entitled to their opinion but 1z has always had plenty of power to clean. It's less about the cleaner and more about the agitation. The proof is in the pudding. Here's a before/after using the products and method I mentioned above.
Edit: after/before... they uploaded backwards. |
12-31-2019, 07:55 PM | #12 |
Rep 12,736
that center tray is toast. not coming back.
i've been curious to try that putty like stuff that can get into cracks to absorb dust, but i haven't gotten any yet... might not work well, i don't know.
Instagram; @roastbeefmike
12-31-2019, 11:43 PM | #13 | |
Rep 368
I'll try the all in one and the detailer recommendations and post the results. |
12-31-2019, 11:48 PM | #15 |
Rep 967
12-31-2019, 11:55 PM | #16 | ||
Rep 368
12-31-2019, 11:57 PM | #17 |
Rep 587
01-01-2020, 01:57 AM | #18 | ||
Rep 368
01-01-2020, 09:00 AM | #19 | |||
Rep 526
01-01-2020, 02:14 PM | #20 | |||
Rep 6,638
01-01-2020, 02:50 PM | #21 | ||||||||
Rep 368
got it. thanks. |
01-02-2020, 10:53 AM | #22 |
Rep 684
I definitely wouldn't replace the plastic trim pieces. First remove all that B.S. Soft touch garbage that BMW is obsessed with using. I used Goo Gone and a micro fiber towel to get it all off. the plastics are all black underneath and some of them look very well without any top coatings. just do not use and abrasives or the higher strength go gone as the abrasives will scratch the surface and the high strength go gone will "bleach" the plastic. when you get all the soft touch crap off you can either wrap it with vinyl or paint them. if you paint them you'll need some type of adhesion promoter and if you want it to look gook and last then a primer, color coat and probably a UV clear coat. Painting them would be difficult, i wouldn't recommend it unless you have experience. The next best thing would be to wrap them. you still should remove the soft touch crap and you need to make sure the surface is completely smooth and free or any scratches or uneven surfaces as the vinyl totally magnifies them. I would suggest using a color close to what the plastic is, either a satin black or a flat.
As for the cleaning I use compressed air, a detail brush and a vacuum. blow all the dust out with the air and the brush then vacuum it out and then use a mild cleaner. Here is a shoot of my vinyl wrapped center console and my steering wheel to show how small surface imperfections are wildly visible. Ill be redoing the steering wheel. -Mark |
