01-09-2020, 03:41 AM | #1 |
Rep 233
M4 vs M2 suspension
Can anybody tell me if they are exactly the same parts, or if not, what’s different between them i,e is it the shock length different or something else different . Wondering if I can fit a Bilsten Clubsport kit from an M4 to an M2?
01-09-2020, 11:47 AM | #3 |
Rep 3,548
Drives: 328d Wagon, M2 Comp, i4 eD35
Specifically, the top mounts and knuckles. Looking at spring or damper PNs won't help because they're different due to the different spring rates and damper tuning. If they're the same, then the coilovers for the F80/82 will fit the F87.
That said, I wouldn't expect the spring rates for an F80/82 coilover to carry over well to the F87. The F87 comes with significantly higher ride frequencies than the F80/82 stock. If you're going to replacing the springs with your own though, then could be worth it.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
01-09-2020, 01:46 PM | #5 |
Rep 3,548
Depends on if your F80/82 is ZCP or not for the spring rates. Dampers should be the same length.
01-09-2020, 02:57 PM | #6 |
Rep 647
01-09-2020, 10:46 PM | #7 |
Rep 3,548
For the rear. It's a progressive spring like the F80/82 ZCP spring and has a higher minimum spring rate, and slightly lower main spring rate.
M 4 FUN606.00 |
01-15-2020, 03:04 AM | #8 |
Rep 4,528
Yr F82 Billy CS kit will physically fit F87 no problem provided the top mounts are the 5 bolt M8 variety [as opposed to 3 bolt m10 version]. Spring rates can be changed/tweaked to suit yr tastes so to damping responses.
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
