01-10-2020, 07:05 AM | #1 |
Rep 326
Used 100.000kms M4 how need servicing?
Hi from Spain I'm going to buy an M4 with 100,000km, what maintenance should I do? I have thought about spark plugs injector filters, dkg oil, lsd oil .. I hope your advice
01-10-2020, 09:42 AM | #2 |
///M Powered for Life
11505
Rep 10,337
100k km is 60k miles. Nothing specific. The car is still young and ready to party.
Just to be safe you should replace the spark plugs and diff oil, change the oil and oil filter and the air filter. There is zero need to change the DCT oil until at least 160k km. People have already done oil analysis on them with that age and they're perfectly fine. Some people have mentioned issues with their charge air cooler, so make sure it isn't drinking coolant. If it is you have to replace the cooler. EDIT: please use ESS this time to tune the car! |
Maxf80M3174.00 |
01-10-2020, 10:16 AM | #3 | |
Rep 326
I'm thinking of putting the 6 new injectors too .. the rest will do what you say .. Well, I will go to stage 2 directly xD filter panel kn + chage pipe kit + resonated downpipes I was thinking of installing bootmod3 ... ESS better? |
SYT_Shadow11504.50 |
01-10-2020, 11:11 AM | #4 | |
11505
Rep 10,337
Remember the spun hub crank becomes an issue as you crank up the boost. If you want stage 2 I would consider the hub crank So you're saying BMW swapped injectors throughout the production run? If so it's news to me |
01-10-2020, 01:08 PM | #5 |
11505
Rep 10,337
If you want bootmod I would limit the torque as they explain here
https://f80.bimmerpost.com/forums/sh....php?t=1579736 |
01-10-2020, 03:19 PM | #6 |
Rep 326
On the injectors I have seen many people with problems in any of them .. with 100k kilometers 60k milles .. I think it would be interesting since I will change spark plugs and coils to put them new too .. but I don't know what you think ..
It is also interesting to put the new lambdas probes. Another question, the adaptive suspension gives some problem or needs some maintenance .. ??? |
01-10-2020, 03:27 PM | #7 | |
11505
Rep 10,337
Definitely new primary O2 sensors Coils last over 100k km for sure. Until they misfire I would leave them alone. Maybe things are different if you're aiming for massive power. Eventually the suspension will need to be replaced, but you're probably fine at 60k miles unless it's leaking. You can always replace it for a non-EDC kit like the Bilstein B12 |
