01-27-2020, 08:31 PM | #1 |
Rep 277
2018 M3 with 4K - Is a very slight "turbo" smell normal when pushing car?
I have a newish 18 M3 with 4K on the odo and I have noticed since it was brand new a very slight "turbo" smell in the cabin when I push the car hard. Is this normal?
Edit - found a post that exactly describes this phenomenon - https://f80.bimmerpost.com/forums/sh....php?t=1203268 Last edited by noone; 01-28-2020 at 03:19 PM.. |
01-27-2020, 08:40 PM | #2 |
I'm Batman!
3949
Rep 1,477
Is this on a track because I've pushed my car on the street in hot weather and have not smelled anything.
S55, 2JZ, M48.00 |
01-27-2020, 08:44 PM | #3 |
Rep 277
No this is going down the highway and flooring it until I hit 130 or 140. You get the idea.
Found this post which describes spot on what I am smelling. https://f80.bimmerpost.com/forums/sh....php?t=1203268 It's still really a brand new car. No fluids are leaking or anything. Never been tracked always babied except when I floor it on the highway occasionally. Maybe protectant oil stuff is still burning off the new parts? |
01-28-2020, 06:23 AM | #7 |
///M SubDriver
1844
Rep 2,787
Drives: 2017 M3, 2020 X7 40i
Absent of any gross mechanical/material failure, I would speculate that what you are "smelling" is normal. But you have heightened sensitivity to something possibly being "wrong" with the car. I think we all do this (heightened sensitivity) with anything that we care about - it is just human nature. This is especially true when something is "new" like your car. Not to mention that at such low mileage, your car is still new with some of that "new car smell" that has yet to burn off - both inside and outside of the car.
I have a '17 M3 that I purchased new. I have also experienced what you are talking about, albeit not as "bad" as you are describing it. My car definitely has a different "smell" after I park it following a boring work commute vs a very spirited drive when I get into it. Following a spirited drive there is a very distinctive clutch/oil/coolant/exhaust/heat smell that is not there after a "normal" drive. Yet there is nothing wrong mechanically with my car. I wouldn't worry about without real evidence of a problem. It will just drive you nuts. If anything, the slight coolant smell you are sensing could be from small bits of engine coolant venting out of the expansion tank - then quickly evaporating due to the heat in the engine compartment. The engine coolant system is designed to do this and may mean your expansion tank is slightly overfilled (but not much). Also, check your HVAC settings, if you have it set to bring in fresh/outside air, if there are any smells coming from under the hood, ingesting outside air will only amplify any smells inside the cabin, even only slightly.
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
01-28-2020, 12:25 PM | #8 | |
Rep 277
I'll just add this and my DCT slight clunk when it shifts into 1st into the "Normal" category. I do love this car except I do need to slow down. I just got my first ticket in 12 years in this new car. |
01-28-2020, 02:46 PM | #10 |
Rep 937
01-28-2020, 04:27 PM | #11 |
Rep 10,509
What is a “turbo smell” OP?
If you smell oil and coolant, then watch out for consumption. Maybe you have some small leaks somewhere that isn’t showing up until the engine bay is hot from hard driving. I drove my f80 hard from the day I took it off the Welt platform and never got any oil or coolant smell If it’s brakes then that’s normal (or drive dsc off) |
01-28-2020, 04:33 PM | #12 |
Rep 20,742
Drives: 2021 911 turbo
What does a turbo smell like ?
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
01-28-2020, 04:54 PM | #14 |
Luxury at the redline :)
9108
Rep 7,563
Seriously, it's probably just blow-off oil from the PVC valve, burning up, while dogging the motor..
Turbo leaking, but dealer says nothing is wrong https://f80.bimmerpost.com/forums/sh....php?t=1545217 |
01-28-2020, 05:05 PM | #15 | |
Rep 1,371
01-29-2020, 03:17 PM | #17 |
Rep 263
01-29-2020, 03:29 PM | #18 |
Rep 164
I get the same faint coolant smell lately from the exhaust pipe, but only when the car is in neutral, and usually soon after the engine is started (ie. not from coming back from a drive). Anybody know why that might be? More importantly, is it possible for there to be a leak that you should care about without the car throwing a fault code?
Background for context: My charge air cooler was replaced under warranty 2k miles ago for a leak that did throw a fault code and I only drove the car about a mile from that point while leaking (and the coolant smell was 10x stronger). Then I changed the oil and got an oil analysis to confirm the leak had indeed stopped. Since I'm still under warranty I had the dealer look at this "new" faint coolant smell problem and they assured me that there was no coolant leaking. |
01-30-2020, 01:10 AM | #19 |
Rep 544
Unless you have a mechanical problem like ,high oil consumption or oil leak or something.
I think it’s just normal anytime you run the car hard, there’s parts on the engine get a lot hotter than it does during normal driving you may not see it on the temperature gage but indeed the heads the cylinders and other parts of the engine are going to be hotter than normal. I’ve seen that on every car I’ve ever owned including my 1994 Chevy pick up truck, you’re running hard it smells different. Drive it like you stole it and don’t worry about it.
1."Luck" is an excuse for people that have failed at their mission to do something! (Allan McNish)
2. I’m not an (EXPERT) I’m just here with an opinion. So don’t hate me. (lukej) |
BMWM5NYC502.00 |
01-31-2020, 12:38 PM | #20 |
The G8X is a disaster. 🤮
931
Rep 988
I had this as well. The local dealer pressure tested the cooling system and it was tight as a drum. The smell comes from mold on the air conditioning evaporator, and is a common occurrence. To eliminate it, remove the cabin filter and spray a disinfectant into the HVAC air intake on the passenger side of the engine compartment. The easiest way to find it is to set the fan at the highest speed and listen for the suction. The evaporator has a tendency to develop mold due to the moisture which condenses on the surface of the evaporator core.
01-31-2020, 05:20 PM | #22 | |
Rep 2,419
