01-30-2020, 01:09 PM | #1 |
Rep 80
Is it better to use paddles for roll racing..
Is there a way to put the car M3/DCT back into auto shifting after starting of a roll race in manual mode or just use paddles to shift?
Dc
01-30-2020, 01:15 PM | #2 |
Legend
97
Rep 166
Yes there is, just tap the shifter to the right and you are in auto once you go wot. The downside is it will go to the first level setting and will drop out of level three if you are in that during manual mode.
Insta: @TexasF80 | YouTube:lvnvevo
Supported by: Limitless Car Care | Braum Racing | Opt7 | MRR Wheels |
dcpatters250.00 |
01-30-2020, 01:16 PM | #3 | |
Rep 446
With my Alfa Romeo Quad, that’s what I would do. Keep the transmission is manual mode, 1st gear, than back into auto upshift mode @ WOT before 2nd year upshift. |
01-30-2020, 01:20 PM | #4 |
Rep 80
That's what I thought. The only way to get on a 40 roll in 2nd gear or 3rd 60 is having it in manual.. so I thought after punching it if it would be best to shift back to auto shifting without messing with the settings
Dc
01-30-2020, 01:20 PM | #5 |
Rep 2,147
Can this transmission not just be left in auto the whole time with fastest shift setting, then just pull the downshift paddle until you hit the desired gear, then hit it and auto upshift? If not, that's friggin quirky.
01-30-2020, 01:21 PM | #6 | ||
Rep 80
Dc
01-30-2020, 01:24 PM | #7 |
Rep 80
Trying to see if someone does this or if it's possible staying in same settings
Dc
01-30-2020, 01:26 PM | #8 | |
Rep 20,742
Drives: 2021 911 turbo
When you toggle between S and D modes, it will go to the last Drivelogic level that was used in that mode. So what you need to do:
The DCT will be in D3
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 01-30-2020 at 04:35 PM.. |
01-30-2020, 01:27 PM | #9 | |
Rep 20,742
And no, it’s not quirky, it is what makes the most sense for the majority of driving conditions.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
01-30-2020, 01:28 PM | #10 |
Legend
97
Rep 166
OR just set it in d3 and on the third honk mash it to the floor, it will jump gears, spin your hub and cost you thousands
01-30-2020, 01:33 PM | #11 | ||
Rep 80
Dc
01-30-2020, 01:39 PM | #12 | |
Rep 2,147
If I was designing this logic, I'd keep it all the same with the exception that pulling a paddle while in D does what other autos do - changes the gear with temporary full manual control that will revert to auto operation at redline or after a period of time while cruising, with steering wheel straight, and low throttle/brake input. 99% of other autos do this, even dual clutches. It gives the same exact control as it does now, where you can throw it in S mode when you want no auto shifting, and the convenience of every other auto with paddles when in D mode. |
gatorfast5021.50 |
01-30-2020, 03:47 PM | #15 |
Rep 3,152
Too much to think about, I'm not smart enough for DCT
01-30-2020, 03:57 PM | #16 |
Rep 10,509
It’s been a while but I recall D3 setting holding the gears to be in the powerband even on the highway and being really quick to downshift if appropriate when going WOT.
Not a bad setting for when you think there’s an impromptu roll race about to go down |
01-30-2020, 04:36 PM | #17 | |
Rep 20,742
I am perfectly happy with that logic on the M-DCT. That's one of the better feature of the DCT, is that it is not programmed to behave like any standard automatic, it more oriented toward performance driving. I find it so much more intuitive than the setup on our RS3. And yes, using the shifter to go in S mode is redundant, just as the shifter is redundant in itself for changing gears. However, only the shifter can be used to flip to D mode.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 01-30-2020 at 04:43 PM.. |
bsmf8x778.50 |
01-30-2020, 04:45 PM | #18 |
Rep 20,742
I prefer to shift for myself. The shift lights are very well programmed, they will tell you when to shift for optimal acceleration when you are at WOT.
01-30-2020, 05:03 PM | #19 |
Rep 3,645
yeah just shift yourself. maybe get some practice doing highway runs so you're not bouncing off the redline. Even if you shift early by 100-200rpm I doubt it will make a significant difference.
01-30-2020, 05:07 PM | #20 |
Rep 14,141
Drives: G82 M4C X-Drive
This. I have both M1 and M2 set to auto to quickly go back without having to press right on the shifter. The DCT goes into manual just using the shifter/paddles anyway.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
behindthen0thing839.50 |
01-30-2020, 07:28 PM | #21 |
Rep 20,742
I rarely use D mode at all. So for me, M1 is Efficient/Comfort/Comfort/MDM/S1 and M2 is Sport+/Sport+/Sport+/MDM/S2. In the rare occasion I use D mode, I use D1, which is the default.
01-30-2020, 08:28 PM | #22 | |
Rep 14,141
However, my M2 is set to: Sport+, Sport+, Comfort, MDM, D3. Since I shift manually anyway, it will automatically set the DCT in manual on the first shift. But when I hit traffic, I want to be in Sport, Comfort, Comfort, DSC, D1. So one press of the M1 button and I'm all set. If I set M1 to manual, then I'd have to also push the knob right. It's just an extra step I like to skip.
bsmf8x778.50 |
