02-02-2020, 12:30 AM | #1 |
Rep 1,154
Drives: 2022 x5 40!
X5 35d engine temp
What should the engine temperature be at on a 2014 x5 35d I’m currently running at 155* . I’m thinking that’s a bit low at a idle my Vw run around 190*
02-02-2020, 05:48 PM | #2 |
Rep 7,554
Where are you getting your engine temperature from? If you are looking at the small gauge on the far right of your instrument cluster...that's not engine temperature.
The little icon reveals what temp is being measured...if its a thermometer sticking out of an oil tin...that gauge is your OIL TEMP. If the icon is a thermoter sticking out of wavy lines (representing water)...that is your engine COOLANT gauge. Again, where are you getting this 155° F temperature from...an app or software...or from the far right gauge on your cluster? {F15 X5 instrument cluster} {E53 X5 instrument cluster}
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
02-06-2020, 10:38 PM | #4 |
Rep 1,154
Drives: 2022 x5 40!
Scan guage
Temp running normal 155 sitting driving 190 Temp was read at the ecu port with a scan guage
