02-03-2020, 05:23 PM | #1 |
Rep 486
Glitter in oil? 1200 miles after new bearings.
This is my first oil change since having my rod bearings replaced with BE bearings.
I have not seen any shavings in the oil. I just see metallic what looks like glitter when I look very close. (Doesn’t show up on oil filter) I opened the oil filter, and saw a few shavings. Probably from the old 173k bearings. I put the oil in a bottle. To see if it’s noticeable when I move the oil around in a see through water bottle. I cannot notice it. But when you shine light inside you can see it. . Is this normal ? |
02-03-2020, 05:29 PM | #2 |
Rep 233
02-03-2020, 05:58 PM | #3 |
Rep 486
No shavings.
I dipped a magnet in it. Nothing stuck to it. I stuck my finger in it multiple times. And a single microscopic black dot is all that came out when I shined my flash light on my finger. Maybe it’s just bubbles That I’m seeing. I’ll send out to black stone next oil change. The good news. I was able to torque my oil pan bolts to 25nm. But I backed them off after reading the horror stories on that. 17nm feels okay. And one of the drain plugs wouldn’t screw in with my hand. But no resistance with 1/4 inch. |
02-03-2020, 05:59 PM | #4 |
OPN DIFF
478
Rep 1,910
Drives: 10' E90 M3 6MT LB
Wouldn't screw in by hand? That doesn't seem right...
'10 LB E90 slicktop/speed cloth/6MT ex. '06 330i 6MT & '10 n54 6MT Msport Autocross vids https://www.youtube.com/user/tigermack https://www.instagram.com/tigermack |
02-03-2020, 06:09 PM | #6 |
Rep 486
It’s a new drain plug. But that shouldn’t matter. It screws by hand until about half way, then need the 1/4 inch. The threads on the oil pan seem to be flattened a bit/ worn. Maybe causing more resistance. It does screw on every time though. Hopefully it won’t be a problem if I pamper it. Don’t want to have to have the oil pan removed again... |
02-04-2020, 06:37 AM | #7 | |
Rep 7,129
Btw what did the 173k shells look like, don't think I saw your post? |
02-04-2020, 08:34 AM | #8 |
Rep 486
02-04-2020, 09:02 AM | #9 |
Rep 7,129
02-04-2020, 09:17 AM | #10 | |
Rep 2,145
Drives: 2011 E92 M3
Cheers,
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
02-04-2020, 05:29 PM | #11 | |
Rep 486
How many oil change intervals do you think it will take to have really clean oil from all the old bearing wear? It could also be from my valve covers that were peeling on the inside. Which I just replaced also. Last edited by bmwpower603; 02-04-2020 at 05:34 PM.. |
02-05-2020, 04:09 PM | #12 | |
Rep 1,168
Just an observation. |
02-05-2020, 06:36 PM | #13 | |
Rep 2,145
Drives: 2011 E92 M3
But, the general case is that S65 bearings look like garbage. The bearings above look terrible for any mileage. Bearings should look like the attached photo of a single bearing from a set of 50,000KM BE bearings that ran 0W40. Also attached is a photo of VAC extra clearance bearings that ran ~50,000 miles (thanks to deansbimmer for sharing this photo). Cheers,
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... Last edited by Scharbag; 02-05-2020 at 06:41 PM.. |
02-06-2020, 02:12 AM | #14 | |
Rep 7,129
These had at least some severe wear, hence not a bad thing to have them replaced. |
08-10-2020, 06:33 PM | #15 |
Rep 298
I took a trip to the tail of the dragon and back roughly about 1200 miles total. Car appeared to run fine the whole time. I got home and decided to check my oil since i burned 3/4 of a quart on the trip, i figured due to higher than normal sustained rpms. i pulled the filter out and examined it and found the following. I confirmed some of the material is magnetic. Most of the driving was high rpm on the highway and especially on the dragon. The only time the car ever, ever, sees 5-7k rpms continuously in 2nd and 3rd gear is through the whole dragon run, however, never redlining. currently @ 78k miles, never tracked, nor supercharged, properly warmed up every single time to a fault. rod bearing replaced with BE bearings and be arp bolts about 25k ago. spark plugs changed every 10k, castrol 10w60 oil every 3-5k. I just changed the oil before i left on my trip so it has at most 1,300 miles on it. At this point the engine still appears to run fine. At this point at minimum, i am going to change the oil again. I dont have the money to pay a shop to tear it apart and inspect the bearings so i can either tear it apart myself and inspect it or just change the oil and monitor it. Logically i think the only way to gauge how bad it is, is to open it back up and inspect it myself and i think the pictures support this, but i wanted to get some opinions first.
07-13-2022, 09:17 AM | #18 |
Rep 650
Drives: Ferrari F430, E92 M3, 335xi
In my (now sold) E60 M5 I had lots of flakes like these... It wasn't the bearings, it was the vanos pump. But that is a different (worse) design than the M3, so it could be other things too.
I would stop driving and drop the pan, check bearing, oil pumps, etc. and replace just in case. |
07-14-2022, 08:17 AM | #20 | |
Rep 2,145
Drives: 2011 E92 M3
Anyway, I am pretty sure it was the oxidation of the inside of the valve covers that put some swarf in my oil after the swap. I now have 53,000KM on the new BE bearings and it is still fine. I have had 3 UOI tests and all seem fine. Was a little bit freaky at the time though.
