02-14-2020, 12:52 PM | #1 |
Rep 1,030
Got A Brake Pad Sensor Error? DIY.
Hey guys so I have a Rotora Superchallenge BBK. So I didn't feel the brake pad sensors were accurate when using BBK. So I made a video for others in case they want their sensors to always read 100% life, and never have a brake pad sensor maintenance warning. This does mean you MUST keep an eye on your rotors and pads old school, use those eyes haha. Hopefully this video is clear enough, if anyone has questions lmk!
JD |
02-14-2020, 04:27 PM | #2 |
Driver
2692
Rep 2,714
You forgot to tell us to smash the subscribe button or something. What did this video tell us that's different? I must've missed it...
E90M 6MT Slicktop Single Humper in need of a diet
JDE92M3874.00 |
02-14-2020, 04:39 PM | #3 | |
Rep 1,030
And maybe you'll enjoy my other videos, if you like M3s then you may like my channel I'm constantly modifying my E36, E90 and F80 M3 JD |
02-15-2020, 07:11 AM | #4 |
Rep 10,663
Some of us have been doing this for 20 years. The brake pad sensor is a ground circuit. Just cut the wire somewhere between the brake pad and the junction box in the wheel well, strip the sheathing off, find the two small wires inside, strip them and connect them together and protect the connection with tape or a terminal end or heat shrink, and zip tie out of the way.
No utube video required, but if you want to help utubers get some advertising revenue, there are plenty of existing brake pad wear sensor bypass videos already out there. |
02-17-2020, 01:04 PM | #5 | |
Rep 1,030
JD |
02-17-2020, 01:18 PM | #6 |
Rep 724
One question: was your error based on your bypass/short coming undone or the mileage counter going over? If the mileage reset is exceeded one can have difficulty resetting via the method you detailed.
Brake Pad Warning Refuses To Reset https://www.m3post.com/forums/showthread.php?t=478138 I went through this issue. I was a able to reset with a foxwell scan tool, but spent quite a few frustrating days trying to reset through the dash. |
JDE92M3874.00 |
02-17-2020, 01:36 PM | #7 | |
Rep 1,030
JD |
02-17-2020, 02:31 PM | #8 |
Rep 724
As I mentioned one needs to check the mileage trigger on the brake resets. Much easier to reset for an open sensor then for when it goes off from the counter.
