03-10-2020, 07:16 PM | #1 |
Rep 1,297
2 layers of PPF in rear fender?
Has anyone doubled up with Xpel in that area? Basically 2 layers sitting ontop of each other? Worth it? Wonder what it looks like?
2022 M3 xDrive Comp
2020 M2 CS (retired) 2018 M3 Comp (retired) 2015 335i (retired) |
03-10-2020, 07:45 PM | #2 |
Rep 3,645
probably better off doing 1 layer. waiting for it to get worn down over time, then replacing it later with a fresh one.
2018 Porsche GT3 6MT 2021 M2C DCT Previous: Ferrari 458 | R35 GTR | F80 M3 | E46 M3 | E36 M3 | Scion FRS |
Rokoz296.00 |
03-10-2020, 08:25 PM | #3 |
Rep 1,899
I've had one layer of PPF on the rear fender and it held up well enough on both F80s I had. One layer is sufficient, there's no need to apply two layers. I presume you could run one layer and once it takes enough abuse you can remove it and swap it out with another.
Retired: 2018 BMW M3 CS, 2018 BMW M3 ZCP, 2016 BMW M3
03-10-2020, 11:27 PM | #5 |
Racecar Driver
1310
Rep 1,986
Drives: BMW M4
It looks really weird when it bunches up due to pitting of rocks. I don't think dual or single ply would make a difference in that area.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
03-11-2020, 04:22 PM | #7 |
Rep 170
But didn't he do the whole car and then only a second layer on the rear fender. That's a little different than just applying 2 layers of the same size on top of each other.
03-11-2020, 04:48 PM | #8 |
Rep 937
03-11-2020, 08:41 PM | #11 |
Rep 4,252
Drives: 2017 M3 MG/SO ZCP DCT
Yes - I put two layers of Xpel on that area. Focused there on my CS after my ZCP got sandblasted on the hips even with factory protection film. Full car wrap and then one layer on top at that location similar to the OEM factory protection but larger. Looks great and is less noticeable than the factory film section.
Might not need two layers but I would definitively take off the factory film and wrap the whole fender or at minimum double the size of the area covered. |
behindthen0thing839.50 |
