03-28-2020, 01:12 PM | #1 |
Rep 7
60k service question
I have a lease that's up in a few months and I recently passed the 60k mile mark. In that 60k service I'm told I have to change the spark plugs and diff and transfer case oil. There are other things too—which I can understand are needed. But the transfer and diff fluid oil and spark plugs I'm not sure of. I have even been told that changing these fluids too early can lead to more problems. On my last e70 x535d lease I went 70k miles and was never told these particular fluid changes were required. Are these fluid changes something I can be charged for if I don't do before turning it in or are these "recommended" fluid changes. The car is almost three years old, it's an f15 x5 35d. Don't mind the cost, it's just the timing is unfortunate being at the end of my lease.
03-28-2020, 01:35 PM | #3 | |
Rep 7
I went in for an oil change and was told these are due. I just don't know if these are vital services BMW can charge me for if I don't do them when I turn it it in a couple months. The 60k service was labelled " preferred" service. I don't know whether to read that as "required" service. The dealer sounded like it was needed. Changing diff and transfer case fluid this early seems like it should not be absolutely necessary right now. |
03-28-2020, 01:59 PM | #4 | |
Rep 2,995
OSUF150.00 |
03-28-2020, 11:11 PM | #5 | ||||
Rep 7
That's what I was thinking. Thank you |
03-29-2020, 01:14 PM | #6 | |
Rep 409
OSUF150.00 |
03-29-2020, 01:54 PM | #7 |
Rep 351
Check your lease contract as it may vary no one hear can give you a sure answer. Your lease contract may specify you have an obligation to maintain the vehicle to BMW specifications meaning simple things from a oil change every 10k miles to filters every 30k miles and 50k service spark plugs etc. Most for a lease normally don't go past the 30-45k mile coverage so they wouldn't need to worry about 50k services. Also transfer case fluid is definitely not part of BMW recommended service although we all change it down the road for bmw its considered "lifetime" so they shouldn't be charging you for that I would try another dealer for lease return.
OSUF150.00 |
03-29-2020, 01:57 PM | #8 |
Wisdom Searcher
58
Rep 193
60K miles in three years? How many miles per year did you get on your lease? Sounds like a sizeable mileage penalty.
Sounds to me like BMW dealer is unhappy they won't make as much money on your returned lease as they usually do.
BLUE HEAVEN
My cars - 2002 Lemans M5, 2006 Interlagos M3 |
OSUF150.00 |
