04-21-2020, 10:52 AM | #1 |
Railside Performance
48
Rep 331
Drives: E92 M3 R8 V10 Q5
Garage List 2010 Ducati Streetf ... [7.00]
2017 Q5 [0.00] 2017 BMW R NineT Racer [5.00] 2010 Audi R8 V10 Ma ... [0.00] 2008 M3 [10.00] |
Removed The Insurance :(
With the social distancing happening and the fact the wife has been working from home since mid March and me only going into work once a week, it seemed a waste to have six vehicles insured and most all sitting. The Audi (sorry for the foul language) has to stay since it just came out of winter storage and the X6 is nice to have for picking up yard materials since I have the extra time. And the bikes are also hitting their prime and taken out of storage.
Question for you, is how can I keep the battery charged while it sits on the driveway? Anything else I should be looking at or be concerned about if it ends up sitting for a couple months? Thanks
E92 M3 Manual
R8 V10 Manual / Audi Q5 Ducati Streetfighter 1098 / BMW R NineT Racer Ducati Monster 796 / Ducati Bronco 1964 Railside Performance |
04-21-2020, 11:01 AM | #2 |
Rep 791
04-21-2020, 11:21 AM | #3 |
48
Rep 331
Thanks for the link. My issue is that the car sits outside in the driveway and I do not feel comfortable leaving the trickle charger outside in the rain. If it was inside than this would be a perfect solution.
E92 M3 Manual
04-21-2020, 11:31 AM | #5 | |
Rep 791
I have outdoor outlets and I could see parking close enough to those and keeping the trickle charger in the connected. Or pull the battery and charge them in the garage. |
04-21-2020, 11:37 AM | #6 |
48
Rep 331
"Just place the ballast inside the car and close the power cord in the jam. Maybe move it a little every now and then to not make a crease in the seal"
You mean inside the operating area or the trunk? Is it best to hook the cables to the connectors in the engine bay or in the trunk? I could pull the battery and bring it inside and on the trickle. Good idea.
E92 M3 Manual
04-21-2020, 11:53 AM | #7 |
Rep 618
or place the whole thing under the hood like I did year ago the storage place was underground with open spot so I just place the charger under the hood ran the cable on the corner of the hood closed and done
04-21-2020, 11:55 AM | #8 |
///M Powered for Life
11502
Rep 10,334
I suggest you do what I used to do. Let the car sit and once every few months, plug the trickle charger in.
In CT the only way for me to remove insurance is to return the plates |
04-21-2020, 12:51 PM | #9 |
Rep 791
Hey OP,
I have a dual bank one. With all the toys you have... https://www.adventurerv.net/battery-...tsfeed_organic |
04-21-2020, 01:05 PM | #10 | |
Rep 305
04-21-2020, 01:07 PM | #11 |
Rep 1,318
When I had to keep one of my other cars in driveway for while I ran a permanent plug in terminal like this directly from battery to wheel well. When not in use or in rain it's still under the car and you don't have to open the car to access it just plug in and go. Depending on your length you may have to extend it but it's still a pain in the neck to be opening hood or trunk every time if it's going to be parked for a while. Once a week just to top it off, that was my method worked well. Shouldn't have to keep it on all the time, a battery should hold for week without charging.
https://www.zoro.com/battery-tender-...-6/i/G3740913/ |
04-21-2020, 01:07 PM | #12 |
Rep 1,300
I've tried the followings when I used to live in an apartment:
1.) Hook up the trickle charge under the hood using the + and - terminal. Leave the whole thing inside the engine bay, there is room around the oil cap area. Fish the extension cord into the engine bay from under the car so the plugs are off the ground in case the ground gets wet. 2.) Take the battery out and charge it inside. Make sure you fold down the back seat so you can unlatch the trunk when you need to put the battery back in. There are other ways to unlock the trunk, but I find the easiest is just to go in the car and through the back seat to pull the release cable. |
04-21-2020, 01:56 PM | #13 |
Rep 63
Get a CTEK trickle battery charger from amazon....looks like you're in Canada so I recommend getting the orange version which is made for cold climate.
To avoid flat spots on the tires you should put extra air into the tires & move the car maybe every 2 weeks. Or you can look into other methods that prevents flat spots such as ramps. |
04-21-2020, 05:23 PM | #14 |
Save the manuals!
6032
Rep 6,753
https://www.amazon.ca/dp/B017K6PH1S/..._.h3NEbB8S0Z2Z
I've heard good things about these. I ordered one for one of our cars as well because it sits outside and isn't being driven. Will post back with my experience once I receive and use it.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
04-21-2020, 06:08 PM | #15 |
Rep 659
from what I have read, you aren't supposed to hook up the charger directly to the battery on this car. It must be charged through the terminals in the engine bay.
I have a CTEK and I charge through the terminals in the engine, you can leave the unit under the hood and run an extension cord out to a wall socket. |
04-21-2020, 07:44 PM | #16 |
Rep 12,736
run an extension cord and put everything inside the engine bay and shut it. a small one will fit. then all you have out in the rain is a rubber cord leading into the garage.
Instagram; @roastbeefmike
04-21-2020, 07:56 PM | #17 | |
Lord Scrip
1823
Rep 3,018
Drives: 2011 M3 Coupe
04-21-2020, 08:46 PM | #18 | |
Rep 791
I don't know if I agree with this. I have three boat batteries and they all are brought inside during the winter. Every couple of weeks I will put that on the trickle charger and they do accept a charge. The led to indicate fully charge takes a few hrs to show up.
04-21-2020, 09:41 PM | #19 |
Rep 4,252
Drives: 2017 M3 MG/SO ZCP DCT
Did u take off just collision or all insurance? Theft and comprehensive still smart to have unless you've got it in the garage under lock and key.
04-21-2020, 11:48 PM | #20 | ||
Lord Scrip
1823
Rep 3,018
04-22-2020, 07:09 PM | #21 |
48
Rep 331
Yes , theft and comprehension is still on the car since it only about 20 dollars a month. thanks for asking and making a valid point.
E92 M3 Manual
04-23-2020, 06:39 AM | #22 |
Rep 791
You are correct. These batteries are not new and are about that age.
