05-09-2020, 09:11 AM | #1 |
Rep 14
M3 CS / M4 CS stereo
I thought I saw somewhere the Harmon Kardon on the CS models is some lower grade version, not sure if that's accurate and if so how specifically ? I didn't find the HK that good at all in the '18 M4 I had, so is it even worse in the CS?
05-09-2020, 10:53 AM | #2 |
Sad ///M noises
4197
Rep 1,798
The CS ditches dual-zone climate control and a high-end 16-speaker stereo in the name of weight-saving, swapping them for regular air-con and a perfectly adequate 12-speaker audio system.
I think the stereo is sufficient in my M4ZCP, I don't blast loud tunes as I like to listen to the car itself |
mtpope3.00 |
05-09-2020, 10:55 AM | #3 |
Rep 403
From what I've read the optional HK stereo for the CS is a 12 speaker system to further reduce weight. I could be wrong.
2018 M3 ZCP
05-09-2020, 11:52 AM | #4 |
Rainbow Racer
1008
Rep 2,540
The usdm M3cs has an HK system, the M4cs has a 9 speaker 205watt Hi-Fi system .
In all honesty, the M4cs's Hi-Fi system sounds pretty good, plays loud enough, aside from a boomy 36-40hz frequency from the under seat woofers, stays pretty flat in output. |
CanAutM321130.50 |
05-09-2020, 01:01 PM | #6 |
Rep 886
are you looking at M3 or M4 CS. As poster above noted, M3 has HK, M4 base.
23 Audi RS6
23 BMW X3 30e Msport 18 M3 CS 17 Porsche Macan GTS 14 Audi S4 |
05-09-2020, 01:10 PM | #7 | |
Rep 20,742
Drives: 2021 911 turbo
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 05-10-2020 at 02:02 PM.. |
Maitre_Absolut881.50 |
05-09-2020, 01:30 PM | #8 |
Rep 20,742
All 3 sound system options have under-seat "bass" speakers, not quite "sub-woofers" though.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 05-10-2020 at 08:19 AM.. |
05-09-2020, 01:43 PM | #9 | |
Rep 20,742
The M4cs gets the M4’s mid-range "Hifi" system.
05-09-2020, 02:46 PM | #10 |
Rep 965
I've had an M4 base with the HK system and now have an M4CS and quite honestly I don't notice much difference. It's not as good per say, but one of my concerns when I first got the CS was the stereo and was happily surprised how great it sounds
CanAutM321130.50 |
05-09-2020, 02:48 PM | #11 |
Rep 20,742
Exact same here
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
05-09-2020, 03:11 PM | #12 |
Rainbow Racer
1008
Rep 2,540
I didn't even know that. Thought it was only these:
Front tweeter x2 Front mid bass ×2 Subwoofer x2 Rear deck x2 Center speaker x1 Where are the rest? |
05-09-2020, 03:17 PM | #13 |
Rainbow Racer
1008
Rep 2,540
I was preparing for the worse. I came from a B&O system on my S5 and I was pleasantly surprised by the CS's Hi-Fi system when I drove it home. I didn't even try it out during the test drive, didn't want anything to cloud me signing paperwork.
05-09-2020, 04:21 PM | #14 |
Rep 14
Great info, so Hi fi has fewer speakers, is the overall wattage lower too? Is the m4 and m4cs the same system because with that chart it almost seems like the m4 cabin won't allow the same speaker locations as m3
My intent is daily driving so a good sound system is important to me |
05-09-2020, 04:58 PM | #15 | |
Rep 712
For some dumb reason BMW put speakers in the doors of the M4CS but covered them up with the door panel.
18 SMB M3CS - MPE/BM3/BMC Filters/Eibach V1's 481.1hp/505.5tq
05-09-2020, 05:18 PM | #16 | |
Rep 8,185
SA688 Harman Kardon 600W I have the former in my F80 and it's barely alright. I don't care nor know THAT much about audio, but I think there is a rather noticeable difference between HiFi and HK in terms of overall loudness - with music playing through Bluetooth and Spotify at max quality - I have to crank it up quite a bit to get some proper untz untz going on. And speaking of untz untz, it does lack the bass of the HK system (which you can further adjust to your liking in iDrive). Everyone's perception is different so best to try it out for yourself. And the SA676 HiFi is the same in M4 and M4 CS, but American-market non-CS M4s do get HK as standard.
05-09-2020, 05:24 PM | #17 | ||
Rep 965
If the HK in an F82 is a 10/10, then the HiFi in the F82 CS is a 8.5/10 easily. Not a monumental difference like what you're describing in the F80 Base system |
05-09-2020, 05:39 PM | #18 | |
Rep 8,185
trendy26423.50 |
05-09-2020, 05:52 PM | #19 |
Rainbow Racer
1008
Rep 2,540
You definitely have to adjust the EQ and bass/treble settings to get a relatively flat response across a broad spread.
I keep getting conflicting info on speaker count on the Hi-Fi system, I see 9 speaker setups as well like on BavAutos website as a speaker upgrade. |
05-09-2020, 05:59 PM | #20 |
Rep 3,645
if you have the 16 speaker HK system i'd recommend using the bimmercode app to change it to the B&O system. sounds much clearer imo. similar to my friends 2014 S4.
2018 Porsche GT3 6MT 2021 M2C DCT Previous: Ferrari 458 | R35 GTR | F80 M3 | E46 M3 | E36 M3 | Scion FRS |
05-09-2020, 06:30 PM | #21 | |
Rep 965
mathys211.50 |
05-10-2020, 05:53 AM | #22 | |
Rep 20,742
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 05-10-2020 at 06:08 AM.. |
