05-24-2020, 05:25 PM | #1 |
Rep 26
Whats going on M Family,
I just bought a 2013 e92 M3. Im having issues with the shift lights not turning on my car. Does anyone else have this issue ? I did get the car from a dealership after handing in my 340 lease. The M3 only has 12k miles. Would like any type of recommendations into modding my car thank you.[IMG][/IMG] |
05-24-2020, 05:31 PM | #2 |
Rep 4,107
It is a setting you can turn on or off. I have iDrive and it is the car settings but I'd have to go look to see as I set it years ago and have not changed it since! If you don't have iDrive the shift lights can still be turned on or off using the steering wheel stalk on the left side od the steering column but I am not familiar with that. Did the car come with the manual? If not you can find a PDF version on the BMWUSA website.
Edit: Just took a closer look at your pictures (beautiful car!) but I see the middle hump indicating the car has iDrive.
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 |
///M Power-Belgium64252.50 SameerG14.50 |
05-24-2020, 05:42 PM | #3 |
Rep 24,867
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
05-24-2020, 05:58 PM | #4 |
Rep 4,107
The instructions are on pages 29 and 30 in the M3 Supplemental Manual.
2021 X3 M40i
05-24-2020, 06:22 PM | #5 |
Rep 24,867
How are you my friend ?
05-24-2020, 06:27 PM | #6 | |
Rep 26
05-24-2020, 06:27 PM | #7 | |
Rep 228
05-24-2020, 06:29 PM | #8 |
Rep 26
///M Power-Belgium64252.50 |
05-24-2020, 06:39 PM | #9 | |
Rep 24,867
Shift lights work only in M-mode or with the MDM button activated on the steering wheel. Just floor it till you go past 7K rpm's !
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. Last edited by ///M Power-Belgium; 05-24-2020 at 06:48 PM.. |
wfdeacon881105.00 SameerG14.50 |
05-24-2020, 06:43 PM | #10 | ||||
Rep 26
I'll take that into consideration. It actually is my first v8 and im absolutely in love with the car. 😍 |
05-24-2020, 06:48 PM | #11 |
Rep 4,107
I am well! How are things in Belgium? Hope you and your family are safe and healthy!
2021 X3 M40i
05-24-2020, 06:50 PM | #12 |
Rep 4,107
Yes, you won't see them activate until you approach the redline.
2021 X3 M40i
05-24-2020, 06:56 PM | #13 | |
Rep 24,867
Busy at work like usual and I'm well . Thanks for asking my friend . #stayhealthyandsafe ! Damn virus !
05-24-2020, 06:59 PM | #14 |
Rep 2,824
It’s a setting in iDrive and/or via the steering wheel stalk. It’s also KEY dependent.
Shift lights do not require M Mode or MDM to be turned on, they can be set independently. |
05-24-2020, 07:01 PM | #15 | ||||
Rep 26
Got it did not know that. Now do I need to have the key inserted ? |
05-24-2020, 07:05 PM | #16 |
Rep 2,824
Nope. I went through this when I rotated keys and couldn’t figure out why my lights stopped working. Now my settings are shift lights always on, regardless of other modes, with either key. I’ve never inserted a key into the socket (CA).
There are a few threads which detail it better than I can off hand, Google search “m3post shift lights” or something of the like. https://www.m3post.com/forums/showthread.php?t=289367 Last edited by wyatth; 05-24-2020 at 07:13 PM.. |
05-24-2020, 07:30 PM | #18 | ||
Rep 26
I will give this a try thank you 🙏🏽 |
05-25-2020, 02:59 PM | #19 |
Rep 6,638
I have them set to come on when I hit the M button but they only light up at high rpm. Apparently they also work outside of M mode if you set it with the buttons on the stock. Only works on DCT cars though.
05-26-2020, 05:12 AM | #20 |
mTekMods
2161
Rep 2,912
Usually on by default in M mode and they come on very fast try to turn it on in the idrive for the M drive settings and give it a go in third gear.
05-26-2020, 08:22 AM | #21 | |
Rep 636
Drives: 2012 Space Grey e92 M3 ZCP
This will give you a better idea of when those shift lights are supposed to come on. You can see it changes depending on what gear you're in:
