06-08-2020, 11:19 AM | #1 |
Rep 91
Tire question
I have a 2016 M4 convertible competition package with 12 mm spacers all around. I need new tires on the rear’s and I was wondering if I can go with Michelin pilot sport 4S in 295/30/20 without any issues? Also when I replace the fronts can I bump those up from 265 to 275 without any problems? Thanks!
And I just realized that probably someone’s going to tell me I should ask this in the tire section but I’m sure you’re all knowledgeable and gracious enough to answer. |
06-09-2020, 11:12 AM | #2 |
Rep 189
Sometimes wearing a tighter shoe does not give you more grip while running, same concept applies. You'll get around 12% increases surface area at the expense of a tighter fit which can cause shear forces on the surface contact with the road.
06-09-2020, 03:48 PM | #3 |
///Multiple
2993
Rep 4,243
Drives: M4 Coupe | M3 | Z4M Roadster
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
Did you know that there's a whole other sub-forum where tires and wheels are the only topics? You might want to try searching there first, because in the last 5 years, someone else has probably asked the same question (and it was answered).
Wheels | Tires -- Sponsored by The Tire Rack
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
06-09-2020, 08:59 PM | #4 | ||
Rep 1,636
I'm planning on running 255/35/19 up front and 295/30/19 on my stock wheels soon. No spacers & stock suspension. Was trying to get 265 but my shop didn't have them, but I should be fine as my wheels come with 255 out the factory anyway. |
06-09-2020, 10:04 PM | #5 |
Rep 85
I am running PS4S in my M3 2016 competition. Stock suspension. No spacers
275 fronts and 295 rear. I am not rubbing the fenders at the front but with your spacers, I think might rub at full lock turn. Hydroplaning may be a problem, but I am not sure how much worse compared to stock 265 in front. I try and drive carefully in the rain. I think the rear is also as susceptible to hydroplane as the front anyway. I chose a wider tire because it fills the wheel well much better, and the tyre is thicker and hence a little more comfortable ride. |
06-09-2020, 10:55 PM | #6 | |
Rep 91
06-10-2020, 12:59 PM | #7 |
///Multiple
2993
Rep 4,243
Yeah, sorry, I'm busy working on a home project. I appreciate you reaching out. I'll reply later today.
