06-18-2020, 02:07 AM | #1 |
Rep 64
Drives: 98.5' E36/M3 15' F80/M3/6SPD
BM3 STAGE 1 Complete
Well everyone. I just flashed my 2015 m3, with 64k on the clock, and wow wow wow. Easy felt like extra 75hp. now she flies. I highly recommend BM3. Paid for the map bundle, have dps, waiting for my charge pipes for install, then stage 2 91. going for 575whp Keep you all posted.
1 issue, i cant make it read from my phone. It did it once, but now when i connect it says no obd read. works from the laptop no troubles. im not big on the technical stuff, so maybe im doing it wrong Last edited by Mracer88; 06-18-2020 at 04:42 AM.. |
06-18-2020, 09:47 PM | #3 |
Rep 64
You are 100% correct. Im just shooting for 1 step at a time. 575 is a final number, on 91 hopefully 525+. Ive seen bm3 stage 1 make 497 wheel.
So i dont think that im chasing wilds hopes and dreams. Mods to come DPS charge pipes intakes |
06-18-2020, 09:56 PM | #4 |
Rep 1,977
Hmm to get 550+ on 91 you’ll probably need upgraded turbos. 91 octane sucks. Excited to see your impressions and don’t forget about some sort of crank hub fix!
06-19-2020, 09:30 AM | #6 |
Rep 577
If you run full E-85 on a proper tune, you should have no problem getting to 575WHP.
current
'18 F22 240i xDrive - FBO '16 F82 M4 ZCP - FBO previous '08 E90 335i Montego Blue Last edited by McBobby Jr; 06-20-2020 at 10:17 AM.. |
06-19-2020, 10:13 PM | #8 |
Rep 64
So as the power climbs, you guys fully recommend the CH fix? I thought since its only roughly 1% of cars, that id just take the risk. she has been unbelievable reliable, literally 0 issuse, with 3 full track days and 64k well driven miles on the clock. i guess ill just test dummy this and see how it goes...
06-19-2020, 11:31 PM | #9 | |
Rep 845
Price of used engines from my research have been in the 8-12k range at most. Price for the crankhubfix with or without retiming is around 3k-4k. Then expected value of new engine = 0.1*12k = 1.2k Then expected value of retiming + fix = 0.1*4k = 400 dollars Total expected cost = 1.6k So getting a 3-4k fix for 1.6k in expected losses at the most liberal assumptions is probably not the best mathematical move. But for peace of mine it might very well be worth it. I would take my chances at a crank bolt capture plate myself for 400 dollars and call it a day. |
06-20-2020, 12:38 AM | #10 |
Rep 600
I like the NPV approach to arriving at a valuation for the feasibility of undertaking a crank hub fix.
Someone is studying or works in finance?
06-20-2020, 08:10 AM | #11 |
Rep 1,195
I’m not good at math and barely graduated high school, so I’m sure the above post makes sense. In any event, you have to ask yourself if the 4K for the crankhub fix is worth the extra piece of mind so you’re not constantly worrying about it.
06-20-2020, 06:10 PM | #12 | |
Rep 1,636
Out of curiosity, how different is traction? That's my biggest fear. Do you spin from a 40-50 roll in 2nd gear? What about the 2-3 shift etc. obv traction on cuts power like crazy I'm talking ab MDM or dsc off |
06-21-2020, 02:02 AM | #13 | |
Rep 64
Im curious what is the capture bolt you mentioned...? Im not totally against the crank hub fix, I feel the stories i read are mostly heavily modded dct cars. For now ill see what i can stretch my $$$ too. I appreciate the valuation. I think its a tough gamble.
06-21-2020, 02:10 AM | #14 | |
Rep 64
So im in CA, and right now ive only had the car tuned about 36hrs and for the last 36hrs its been very hot here. i havent gotten alot of extra wheel spin yet since its warm out, the tires grip. I did notice on cold-ish tires and cooler temps, a 2nd gear roll on, got me spinning 2nd gear nice and much harder than stock.
(Side note, im a track instructor, and amateur pro driver, so to me i didnt notice an aggressive change, i was actually looking for wheel spin. I love me some oversteer.) but as i mod it i assume the tire spin will increase. Stage 2 and dps,monday. No spin into 3rd yet. im sure with colder ambient temps, ill have more traction issues. most of the tire spin issues ive experienced come from the dct cars. i drove a stage 1 dct car, and 1-2-3 all spun way harder than my manual car. go figure. but he also had dps, my dps go on monday when i have spare time, and re flash to stg2. ill come back and write up on it. Quote:
06-21-2020, 02:15 AM | #15 | ||
Rep 845
1. Bolt backs out spins the hub 2. Overwhelm the friction plates and spin the hub In regards to 1: The crank bolt capture plate sold online for 99 usd from vargas and about 300 in labor makes it impossible for the crank bolt to slowly weasle itself out and solves this problem. Typically this type of spin from what i have searched happens on stock, tuned, or really any vehicle, sometime due to it not being torqued properly from factory and at times it is suspected to be with fast rpm shifts (kickdown) or repeated abuse. The most common type of spin. In regards to 2: This one you need to the full crankhub fix as you pin it and keep the whole unit together. If you are going e85 or upgraded turbos i would not feel confident with just cbc. With this type of spin the cases seem to be isolated to very high torque output cars, overwhelming the friction discs and spinning the hub, it takes a lot of power to do this, seems to be the one most correlated to high torque numbers. I think keeping the bolt from backing out is a major risk mitigator for a low cost but it is not the full solution, i have honestly looked up this issue for quite a while and from the reported cases most seem to occur right here, bolt found either to come loose, or for the few lucky ones it was just about to back out before they did the fix. This is the inherent flaw in the engine design and is fixed with the capture plate. The second type of spin is not due to an engine flaw, it is due to pushing too much power on stock internals, i consider the crankhub to be a stock internal that is susceptible to spin with high horsepower. The second type of spin is purely a mistake of messing around with too much power without properly prepping the engine. While the S55 is a durable and reliable engine it cannot make over 600 whp reliably without upgrading the crankhub as it was not designed for it. |
06-21-2020, 02:36 AM | #16 | |
Rep 64
i dont get kick down, i have a manual and im gonna look into the soultion u've suggested.. Im shooting for close to 600hp. will most likely stay 91. Im not 100% yet if ill chase that hard for 600, im just curious to experiment .
im a track guy, and have realized that there is definitely something called having too much power. I buy m3s for the handling characteristics. power was never my main focus, but i wont say that its not nice having gut twisting power. especially when my date is unexpected of my driving skills, and then the almsot 500tq she feels after dinner. my e36 track car is 275hp. if i get closer to 600 or plan to do turbos 100% id do the ch fix. Quote:
06-22-2020, 09:25 AM | #17 | |
BimmerPost Supporting Vendor
24392
Rep 191,249
For that kind of power on stock turbos, you need an E85 custom map
06-26-2020, 12:50 AM | #18 |
Rep 64
I know that ill need a full e85 tune for get the upper 550s, i didnt mean 91 and 600hp. I meant like my ultimate goal would e 600. But as of last night, I did the VRSF DPS and a 91 stage 2 tune and shes a ripper!!!! holy cow, its un-real the change in speed and response. I look forward to running an e30 mix. Ill write up some more...
06-26-2020, 01:55 AM | #19 |
Rep 256
As long as you plan on staying on an OTS BM3 map you shouldn't have to worry about CH. Unless you drive very aggressively ( dropping 2 gears in a moment and in your case money shift)
Get a CH fix once you plan on going e85 to reach the power you're looking for and to have a great safety factor. The stage 2 map is plenty for the street and even track, to put the power down better I'd suggest limiting boost in 1-2nd gear. Even if you don't do a CH fix at full e85 the worst would be a retime maybe so that's a risk, going with bigger turbos will put you at a way bigger risk of damage without a fix. |
fiveohwblow3633.00 |
06-26-2020, 02:34 AM | #20 | |
Rep 64
I appreciate the advise. Im no animal when it comes to abuse. Believe me i use my cars well, but never reckless. Im actually thinking of reducing some of the power from 1st gear maybe 2nd. Ill try the e30 mix and see how it goes.
06-26-2020, 04:45 AM | #21 | |
Rep 81
06-26-2020, 05:26 AM | #22 | |
Rep 307
