06-21-2020, 05:38 PM | #1 |
Rep 451
Build Journal's BBK; Brembo calipers on OE rotors
Hey guys,
Just recently saw a video on YouTube from BuildJournal about Brembo calipers retrofit kits for E46 & E92 M3. Price is 950$ for the E9X front kit, quite the bargain. It seems new, I reached out to suggest they get on the board to talk about the kit. Link; https://thebuildjournal.com/shop/all...90-e92-e93-m3/ Description: Upgrade your E90 E92 E93 M3 brakes with our 4-pot Brembo BBK retrofit kit. Featuring new Brembo Renault Mégane RS Trophy-R calipers, custom 6061-T6 aluminum caliper brackets made in the USA, stainless steel brake lines and all hardware necessary for caliper install. Rotors and brake pads not included. This is a direct bolt-on kit for the OEM 360×30 rotors. [IMG]https://thebuildjournal.com/wp-conte...ofit-kit-1.jpg[/IMG] |
06-21-2020, 11:35 PM | #4 |
Pho is yummy
768
Rep 938
Good price, but freaky parts kit come with pads. This one doesn't.
2008 | 6 SPD | Fox Red | Forgestars | B&G Springs | M Performance Exhaust | Catless X pipe | Alpine Tune |
06-29-2020, 07:38 PM | #9 |
Rep 12,736
its 95% a rotor inefficiency problem, but people will try to convince you otherwise.
Instagram; @roastbeefmike
06-29-2020, 08:33 PM | #10 |
wannabe
252
Rep 819
Is the caliper the same on the evo 7/8/9 as the Renault? Im curious.
E90 M3 - 6speed - slicktop - single hump
06-29-2020, 09:17 PM | #11 | |
Rep 334
i asked this directly to one of the ppl at buildjournal when they were hyping up their kit and there was no response. for ppl after flashing a brand name brake on the street, i guess this is another option. for actual performance, this is not it. |
06-29-2020, 09:36 PM | #12 | |
Rep 12,736
really means nothing, because rotor tech is what makes the biggest difference. then these kits come out and people want brembos for $1k. there have been too many problems with these kits you would think it would be obvious, but people aren't interested in reading to educate themselves, they just want brembos.
06-30-2020, 04:12 AM | #13 |
Rep 6
06-30-2020, 07:29 AM | #14 | ||
Rep 451
You say it's common knowledge our OE rotors are the culprit. Is running an upgraded disc / pad / fluid combo on stock calipers better than upgraded calipers/ pad / fluid on stock rotors? Can you provide background information on that? The only thread I could find with proper information is this; BBK vs Stock (on-track performance) - data? https://www.m3post.com/forums/showthread.php?t=1435221 The Essex guy isn't exactly clear on what is the biggest weakpoint in the OE braking system for track usage, making a case for rotors and calipers, while numerous members point to pads, fluids and lines being sufficient. |
06-30-2020, 08:48 AM | #15 |
Rep 3,994
A kit like this does improve braking feel and stability under high-speed braking from my experience (only street driving), but being a front only kit, the rears also need some help in that department.
I have tracked my car on stock brakes with upgraded fluid and track pads. While rotors do take a beating, I didn't have a issue with brake fade, but as they heat up the car dances around under heavy braking from high speeds. Brake cooling would probably help a lot, but there isn't really any elegant solutions for that from what I have seen. With my F8x brake setup, stability under high speed heavy braking has greatly improved, while the f80 rotors are bigger, I don't feel they make much of a difference, at-least not as noticeable to me as a fixed caliper does. The stock brakes are more than enough for the street, but maybe I'm not beating on them hard enough as some folks, just spirited drives, I save the prolonged beating on the car for the track.
06-30-2020, 10:14 AM | #16 | |
Rep 12,736
there seems to be no shortage of problems with these kits- calipers touching rotors, pads not making full contact with rotor face, pads not centered on rotors or pistons, and lovely variances in parts on each side of the car that are supposed to be the same. running and upgraded pad, fluid, and rotor is better than running an upgraded caliper. undebatable. my main points have always been this- the job of a brake system is to slow the car by converting friction into heat. if the brakes can't get rid of the heat, they fail. so lets over simplify and break down the brake system. 1. caliper- squeeze the pads into the rotor 2. pads- provide friction material 3. rotors- receive friction (heat), dissipate heat. the simplest way of improving system efficiency is to help it dissipate heat. the caliper does not dissipate heat. quite the opposite- calipers are designed to produce the heat. in fact, you don't want heat to get into your calipers. caliper pistons are often designed with ventilation cut-outs to help reduce heat transfer from the pads into the pistons and brake fluid. take a look at an ap racing rotor and you'll clearly see the rotors have many more cooling vanes between the rotor faces. rotors do have some heat capacity, but they aren't heat sinks, they are designed to absorb and get rid of heat. so adding a more rigid caliper with a larger pad surface is going to feel better in daily driving. i wouldn't debate that argument. however, upgrading a caliper and pad, but failing to upgrade rotors is just going to overwhelm the rotors at most tracks. price out the cost of one of these retrofits, good pads, stainless lines, good fluid, and rotors. its not much less than a kit that addresses all of the above concerns, not just a caliper that looks cool. if you don't want to spend the $4k on a bbk, i get it. i'd recommend quality fluid, quality pads, and pfc direct replacement rotors. you can probably do it for about $1,700. https://pfc.parts/product/357-062-6364/
derbo3611.50 Longboarder3436.00 |
06-30-2020, 05:51 PM | #18 | ||
Rep 12,736
slowdown_dan285.50 |
06-30-2020, 08:10 PM | #19 |
Rep 75
fwiw, i have zero issues with the freakyparts brembo kit, I purchased it knowing it wasn’t a track upgrade as I don’t track this car. i bought it for easy pad changes, weight reduction and asthetics. i’ll be adding the pfc DD rotors to drop more weight.
06-30-2020, 09:05 PM | #20 | |
Rep 334
i think this is exactly the target demographic for these kits and it's definitely a great way to get that aesthetic goal while upgrading street performance. i'm on OEM calipers, pfc rotors + pfc pads and endless fluid. it's good enough for me at the track but i still don't push 80% on braking heavy tracks |
06-30-2020, 09:34 PM | #21 | |
Rep 10,662
For weight reduction, I bought lighter Apex wheels and have run only light Michelin or Continental tires. Before I would spend $1700 on a set of fancy rotors to go with $800 Mitsubushi EVO 4 piston Brembo calipers, I would spend 2500 on a used 6 piston 380 mm BBK that would definitely improve braking. Since I’d rather spend $2500 on something that does more than just look good for my driving, I still run stock calipers and rotors. Last edited by pbonsalb; 07-01-2020 at 06:55 AM.. |
06-30-2020, 10:48 PM | #22 | |
Derbo Tuning
3612
Rep 3,026
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
