06-29-2020, 09:00 PM | #1 |
Rep 139
Hello to everyone. The dealer did transmission pan gasket change under warranty because it was leaking. The only thing that I am worried about is that they added just 2 quarts of oil instead of 7. Any ideas why they used only 2 quarts?
06-29-2020, 09:13 PM | #2 |
Rep 121
They did not follow the proper procedure...idk..2 quarts seems like what it would take after installing the new pan and putting new oil until it runs out when the engine is OFF.
06-29-2020, 09:40 PM | #3 |
Rep 139
06-29-2020, 09:55 PM | #5 | |
Rep 1,564
Average oil change will use 3.5 to 4 liters. Only using 2 is way to low and indicates they only filled it with the engine off. All ZF8HP transmissions made have to have the final filling procedure done with the engine running and after the rpm was brought to 2500rpm for 30 seconds while in park, plus shifting through all gears in idle and transmission temp has to be below 120 degrees if memory serves. Whoever did yours didn't know what they were doing if they only used 2 quarts. The reason why it has to be done with the engine running is as soon as you turn it off, oil runs out of the torque converter back into the pan and will give you a false full oil reading. |
06-29-2020, 09:59 PM | #6 | ||
Rep 139
06-29-2020, 10:05 PM | #7 |
Rep 1,564
I am mobile right now otherwise I would just post it again but if you search the forums, you will find the actual ZF oil change procedure document, I would download it and read up on it and then grill them on it. Its impossible for it to use only 2 quarts unless it's a typo. Until then be careful of any steep downhill drives. Transmission will probably feel ok like mine did on normal driving so it's deceptive when it's low on oil.
06-29-2020, 10:39 PM | #8 |
Rep 97
2 quarts is way off. Even if they did a slack job and only filled it once while engine was off - it should still take in about 3 quarts at the very minimum. So something is not right here.
After that 3 quarts, you need to warm up engine and transmission and run through each gear and then you can add another 1-1.5 quart. So all in it will take about 4-4.5 quarts. Unless as it was suggested, they put old oil back in, but for a dealership that's a big no no. |
06-29-2020, 11:27 PM | #9 | |
Rep 2,995
06-30-2020, 05:01 AM | #10 |
Rep 364
Drives: F15 M50d / ex E90 335i / Panda
My dealer also has a procedure, that advises the mechanics to put back the old fluid in case of any transmission related jobs regardless of the mileage.
Silververtu231.00 |
06-30-2020, 06:37 AM | #11 |
Rep 43
'17 F16 x35, '15 F83 6mt - Best X5 cosmetic mod is an X6 |
06-30-2020, 08:02 AM | #12 |
Rep 1,564
06-30-2020, 11:45 AM | #13 |
Rep 139
So guys, I called them today. They told me that my oil was good and clean enough to reuse it, and they added only 2 quarts of new fluid. I don't like that but at this point where is nothing to do.
06-30-2020, 12:17 PM | #14 | |
Rep 364
06-30-2020, 12:37 PM | #15 |
Rep 1,564
Disturbing but better then being low on oil. Perhaps they do this when under warranty to save themselves a buck, BMW transmission oil is 200 dollars a quart, EXACT same oil direct from the manufacturer ZF is about 25 a quart. How many miles on your X5?
06-30-2020, 12:41 PM | #16 |
Rep 1,564
Could you ask if they only do this when the service under warranty? I have a feeling if it's out of warranty they will be more then happy to put in new oil at the owners cost but reuse old oil when it's under warranty to save themselves money.
06-30-2020, 01:18 PM | #17 | ||
Rep 139
06-30-2020, 01:26 PM | #18 |
Rep 1,564
38k is still within spec as ZF doesn't recommend oil change until 60k or more so I guess reuse of the oil isn't that big of a deal assuming they were absolutely meticulous about not contaminating it. Still kinda raises an eyebrow though.
06-30-2020, 01:39 PM | #19 | |
Rep 364
06-30-2020, 09:21 PM | #20 |
Rep 97
That's like vomiting food and then eating it again because it's still good enough you know, still has some nutrients left. Damn. 2020 United States of America and it's a BMW dealership ladies and gentlemen. Now I've seen it all.
Oh wait. It's UK/EU? Then I guess it's kinda ok-ish? Probably dealers have different approach. |
JMAN1111227.00 |
06-30-2020, 09:29 PM | #21 | |
Rep 139
USA market |
06-30-2020, 10:56 PM | #22 | |
Rep 2,995
Picasso37.00 |
