08-04-2020, 05:00 PM | #1 |
Rep 635
edc module removal - cant find it for the life of me.
Hey guys, looking for the EDC module to remove it due to suspension change. For the life of me I can not find it in my 2013 e92 M3. They say its passenger side panel behind the rear seat. But I cant seem to locate it. Maybe Im getting blind in my old age. Any help would be greatly helpful.
Thank you, |
08-04-2020, 06:27 PM | #3 | |
Rep 301
I'm just asking to learn; why do you need to remove the EDC after changing your suspension?
"…And the longer you deny yourself that M satisfaction the more unhappy your soul will be…. Get busy living or get busy dying and stop sweating the small stuff!" i001947
08-04-2020, 07:50 PM | #4 | |
Rep 635
NiDrive, I had installed a KW Club Sport non EDC suspension kit on my car. This will give you a fault saying EDC is failed go see a dealer. I had coded it out, but the EDC module will continue to trip the message unless you unplug the blue connector from the module. So now, my car does not give me an error for not having an EDC suspension and I did not have to buy a emulator for a few hundred bucks to get rid of the code. |
njdrive97.50 |
08-05-2020, 07:39 AM | #5 | |
Rep 301
08-05-2020, 01:51 PM | #6 |
BimmerPost Supporting Vendor
8274
Rep 18,859
Located behind trunk liner on passenger side, just above battery.
Simply unplug the blue connector from the DCE and code module out. Connector housing is removed in this photo, that's not necessary unless you're installing the Macht Schnell EDC Emulator.
10-20-2022, 09:48 PM | #7 | |
Rep 865
Chris, 2008 E92 |
10-20-2022, 10:03 PM | #8 | ||
Rep 1,503
2011.5 E90 M3 DCT ZCP Slicktop
Davisca4552207.50 |
10-20-2022, 10:16 PM | #9 | |||
Rep 865
Thank you very much!
Chris, 2008 E92 |
Bimmer Barney1251.00 |
12-20-2022, 09:36 AM | #12 |
Rep 465
12-21-2022, 12:07 AM | #13 |
Lord Scrip
1823
Rep 3,018
Drives: 2011 M3 Coupe
If you coded it out properly it would not show in the device list. I suppose it’s debatable but to “code out” means the car doesn’t know it’s there anymore. Even if you physically remove it the VO will reflect it until all references to the option are gone.
12-21-2022, 01:03 PM | #14 | |
Rep 465
Not sure what I'm missing to get rid of the code, but it's not a big deal. |
12-21-2022, 05:41 PM | #15 | |
Lord Scrip
1823
Rep 3,018
Tommysalami563.50 |
12-22-2022, 09:47 AM | #16 |
Rep 465
hmm, I edited the VO and did process ECU / CAS and then change job and FA_write. I'll have to check whether I did it for the NFRM
12-22-2022, 10:20 PM | #17 |
Lord Scrip
1823
Rep 3,018
So as I recall and it’s been a while, there are 2 modules that hold the VO as a config. If you remove the particular VO’s and change values it will hold your values but not “remove the values from the config” so to say. I recall I had to remove the values and then write them immediately to my NFRM and either CAS or Kombi, that’s where I get foggy. Both holders of that VO list have to be written to for the VO to be gone. But 100% you have to write those changes. Then if you query the car those VO’s will be gone as well as some of the linking features to other modules. This usually removes most of the coding changes you would be making in INPA or whatever you are using. Then if you query the module list again EDC module should be gone. My picture shows original VO on left (pre Combox) and change VO on right (w/Combox). I had to remove some VO (forget), add 644 and add 6VC in this case. After doing the aforementioned I never see the old VO’s nor the modules.
07-24-2023, 08:23 AM | #18 |
Rep 221
Is it only the blue connector that needs to be removed or does the white connector need to be removed as well for coding out the EDC... because I see some post mentioning to remove the white one as well.
2011 E92 M3 mods: Alex tune, mod'd X-pipe, MPEv2, MS intake stage 2, ESS power pulley, Monoball bearings, SSFBs, PFv3 rotors, MFactory DSv3, RE SSK, Voltphreaks Li batt.
For sale: E92M3: BW Race muffler, front thrust arms, stock muffler, 19" Vorsteiner VFF103 rims Z4MC: KW V3 coilovers (rears) |
