08-28-2020, 12:45 AM | #1 |
Rep 384
Need help, running very rough!
Got these codes tonight. Can anyone help me figure out what's going on?
// 1) 2B39 Combustion misfire with cut-out cyl 5 // 2) 2B3A Combustion misfire with cut-out cyl 6 // 3) 2B3B Combustion misfire with cut-out cyl 7 // 4) 2B3C Combustion misfire with cut-out cyl 8 // 5) 2B41 Combustion misfire with cut-out several cyl // 6) 2B57 Motor emergency programm activated // 7) 2796 Motor emergency programm activated |
08-30-2020, 02:03 AM | #2 |
Rep 151
Drives: 2013 M3: E92, ZCP, DCT
My guess is throttle body actuator failure.
-Mike M.
2013 M3 [E92, Alpine White, ZCP, DCT] 2016 i3 REx [Tera World, Capparis White] |
09-25-2020, 04:56 PM | #3 |
Rep 384
09-27-2020, 09:38 PM | #6 |
Rep 384
VitSports650.50 |
09-28-2020, 02:26 AM | #7 |
Rep 151
You've got me stumped. I'd look into fueling issues: maybe your fuel pressure sensor or moving your injectors around to the other 4 cylinders to see if the misfire follows them. If it's your injectors, I'd have them serviced. I went through Mr. Injector (online) for my motorcycle and was very happy with it. My M3 will be getting that service too soon enough.
Also I'd double check to see if your plenum is seated properly, which you'll probably do anyway to get to the injectors.
-Mike M.
09-29-2020, 05:56 AM | #8 |
mTekMods
2161
Rep 2,913
run ista test plan on the Idle Control Valve,
followed by checking the exhaust to header interface for a leak, then verify accurate lambda readings.
09-30-2020, 03:59 PM | #9 |
Rep 384
10-10-2020, 06:30 PM | #10 |
Rep 384
So I believe my mechanic found the problem. He did a lambada probe test above the primary cats and found out that my upstream O2 sensor on bank 2 errors out above 500 celsius, which would explain the misfire and limp mode.
Three Pedal Steve876.50 PACarGuy686.50 |
