09-04-2020, 09:20 AM | #1 |
Rep 16
considering buying 15' M3
So i was considering buying an F80 m3 m/t, but this SCH issue has got me second guessing myself.. I knew about this issue, but never looked in to it in depth until a few days ago.. coming from the W204 C63 amg it kind of reminded me of the head bolt issue (blown out of proportion IMO). I've been deep in the forums reading up on the SCH issue. It seems that it's mainly dct models that are tuned and alot of them are in Cali... idk what's going on with gas quality over there.. granted there are m/t cars that have sch..
all that aside.. is this issue blown out of proportion? If i buy this m3 i want to do the typical stuff BM3, down pipe, charge pipe, intercooler, spark plugs, no e85. really just want 500whp. Am i in danger of spinning my CH if i do this? I'm not willing to fork up 4-5k as preventative maintenance. I mean i've read people have spun their CH even after upgrading it lol. i dont wan't to be in fear of my ch going bad if i rev the fk out of the car (which it's designed to do) or if i do a bad downshift where the car is over revving (i probably won't do this).. people are making it sound like the CH is made out of glass. |
09-04-2020, 09:38 AM | #2 |
Rep 4,988
You don't need to do anything preventive other than charge pipes imho. Those are a no-brainer. Simply put, they're a weak point, and good ones from any brand are a cheap upgrade worth the peace of mind.
That said, the SCH issue is rare. Even more rare is a SCH that results in engine damage. Unfortunately, I managed to do both with just a JB4 and down pipes, and needed a new motor: New engine/Gintani hub after spun crank hub https://f80.bimmerpost.com/forums/sh....php?t=1752927 Just my 2 cents, but I would at least put $4-5k aside for a new crank hub if you're going to tune it in any way. That way, if you do spin it, you have that $ there for the upgrade. Crank bolt capture is another option, and could save you some $, but again, is no guarantee. Unfortunately, the numbers we have aren't fantastic or definitive. It's manuals. DCT. Tuned. Stock, etc. And driving habits seems to have little correlation either. It's a gamble with these cars, even without a tune, but it's an incredibly small risk, so there's that. I wouldn't *worry* about it, but I wouldn't stick my head in the sand and just ignore the risk either. Just make sure you have an extended drivetrain warranty, whether you tune it or not.
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
09-04-2020, 07:53 PM | #3 |
Rep 502
The consensus seems to be that the issue is definitely blown out of proportion. If it still keeps you up at night though you can always just install a CBC for a couple/few hundred bucks and call it a day. People swear by them since there have been no reported SCH from people running just a CBC
bsmf8x778.50 |
09-04-2020, 10:02 PM | #4 | |
Rep 1,636
93 stage 2 + not money shifting + CBC should be fine. You can really just leave it stock and avoid SCH entirely as the chances are close to none when you're stock. The car moves stock, test drive one with TC/DSC off. |
09-04-2020, 10:10 PM | #5 |
Rep 502
I thought all the spun hubs with CBC were on cars that also had an aftermarket hub? I always see people in the crankhub debate threads preaching how there's "no reported failures with just a CBC" haha
09-04-2020, 10:17 PM | #6 | |
Rep 1,636
HyeM3464.50 |
09-05-2020, 08:12 AM | #7 |
Rep 6,991
Drives: 15 F80 M3, 22 G01 X3 30i
You're in danger of spinning the crank hub with a stock F8x car if you beat the hell out of it, but barring that, you should be OK. My 2015 has Alpine Stage 2, AA midpipe, and Alpine GTS-level tune for the Diff and DCT, plus BMC drop-in air filters and charcoal-element delete. Not planning on doing downpipes or chargepipes, since my tune retains stock boost levels. If I were to go to higher boost level, chargepipes would be my next modification and possibly a higher-capacity heat exchanger.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
09-05-2020, 09:03 PM | #8 | |
Rep 16
spuntyb4066.50 |
09-05-2020, 09:05 PM | #9 | |
Rep 16
09-05-2020, 09:08 PM | #10 | |
Rep 16
bsmf8x778.50 |
09-05-2020, 09:10 PM | #11 | |
Rep 16
09-05-2020, 09:30 PM | #12 |
Rep 502
If you're just going stage 2 I wouldn't worry about spinning the hub as long as you aren't tracking the car, using launch control, or dumping the clutches doing rolling burnouts and stuff. But if you want to abuse the car like that then a CBC should be more than enough. Just my 2 cents though
09-05-2020, 10:00 PM | #13 |
Rep 922
Just do a crank bolt capture if you're tuning it, and be aware that as your horsepower goals increase so does the risk. E85 tunes and upgraded turbos seem to feature among most of the failures.
If you're totally stock... don't sweat it. If you have no warranty, maybe add a CBC whenever you end up having some work done or have the car at a workshop, but don't go out of your way to do it because this issue is extremely rare for stock engines. |
bsmf8x778.50 |
09-05-2020, 10:33 PM | #14 | |
Rep 16
09-05-2020, 10:34 PM | #15 |
Rep 16
I think I’m going to pull the trigger on the f80 m3 tomorrow.. I’ve always been team Bmw at heart.. although amg wasn’t a bad team to be on .. thanks all for the advice. Will post pics soon!
09-05-2020, 10:56 PM | #16 | |
Rep 922
Are you going to at least up the tyre size? 430hp isn't slow man, it's more than enough to light up the tyres most of the way up to the speed limit. The car very easily kicks out the back end in a corner, even at fairly high speeds. At least get the hang of the car before you tune it and make sure you can catch the slides otherwise you'll never even make use of the power. Reminds me of that dude who got roasted here posting his LA canyon run while displaying some piss poor driving. Car was tuned, what for I don't know because the guy could barely control it safely at normal speeds A lot of people just tune these cars to post numbers |
2011ninja3415.50 |
09-05-2020, 11:17 PM | #17 | ||
Rep 902
https://youtube.com/user/Jbonly21
09-05-2020, 11:20 PM | #18 |
Rep 922
09-06-2020, 06:18 AM | #19 | ||
Rep 4,988
Do it!
bsmf8x778.50 |
09-06-2020, 07:56 AM | #20 |
Rep 4,203
I really would not be scared of stg 2 93 over stg 1 93. BM3 tune stg 1 is the biggest increase. Very small after that. See below
Stage 1 93: up to 22%HP / 23%TQ Stage 2 93: up to 24%HP / 26%TQ +2/3 over stg 1 Stage 2 E30: up to 26%HP / 26%TQ +2/0 over stg 2 93 & +4/3 over stg 1 93 These are targets and only if you have all the supporting mods to achieve the target numbers I also would do the GTS DCT flash...it help with gear slamming and much smoother Tune, adapt and enjoy |
09-06-2020, 08:04 AM | #21 | |
Rep 16
09-06-2020, 08:06 AM | #22 | |
Rep 16
