      09-11-2020, 12:14 PM   #1
Ursan
Ursan's Avatar
53
Drives: '12 128i, Volvo 945t & 780t
Question Adding a cicuit
My '12 128i has only a single USB port (not for charging) and only a single 12v socket. Both are inconveniently placed in the rear of the center console.
I want to use one of those "add-a-circuit" to piggyback onto an existing fuse on the panel and just run the length of wire to where ever I need it to be.
My question is what fuse should I use? I'm thinking radio or something that's switched with the ignition.
Thoughts?
"Rear Wheel Drive, the way God intended. If a car is being pulled from the front, doesn't that mean it's being towed?"
      09-11-2020, 12:24 PM   #2
Soterios
BXR
575
Drives: 2012 135i
If you're just adding a charger, current draw will be minimal, so it won't matter to 90% of those fuses.
Radio should be fine.
2012 135i M Sport Alpine White
1addicts
