10-26-2020, 01:54 PM | #1 |
Rep 645
469M Wheels
Hi everyone,
I recently picked up a 14 X5 M Sport from thr main BMW dealer here in Auckland. I only just noticed that on one side of the car the wheels have the small M badge/sticker on the wheel, but nothing on the wheels on the other side of the car. To me that seems unusual. I haven't taken the wheels off to check for Ronal branding yet. Question is - was the 469M ever manufactured without the little recess for the M badge? Thanks |
10-26-2020, 02:31 PM | #3 |
Rep 651
I don't know if they made an M version with a badge, and non M version without or not. But I believe they made/make aftermarket versions of them, that did not have the badge.
Probably best to take them off, and check. If they all were the original that came with the vehicle, they should all have the same indent/recess for the badge. So someone has definitely replaced a couple wheels. |
10-26-2020, 03:09 PM | #4 |
Rep 645
Yeah, it's really weird. I have emailed the salesman at the dealership to ask what the story is with them. I tried to take a couple of pictures of the inside of the spokes and there is one picture that seems to show 'United States' on the back of the spoke which is odd.
10-26-2020, 03:11 PM | #5 | |
Rep 645
10-26-2020, 04:10 PM | #6 | |
Rep 651
I suggest asking the dealer to remove the wheels, and compare what info is added to the casting, or stamped into the inside/backside of wheels. |
10-26-2020, 08:18 PM | #7 |
Rep 645
I just went outside and had another closer look - I think I know what has happened. At some point, the two wheels have had their faces machined, which has taken away the surface to the extent there is no longer a recess for the M badge. I measured the depth / width of the outermost machined surface of the wheel lip. On the 'good' wheel, it's about 10mm - and on the wheels that have no M badge it's closer to 15mm, so from a cross sectional perspective it's probably 2mm that's been taken off the face. But of course now the issue is the wheels look different and the center caps I have noticed also don't fit properly. Is this something I should ask the dealer to fix via two replacement wheels, or would that be a dead end given this is a six year old vehicle now?
10-26-2020, 08:59 PM | #8 | |
Rep 651
Unsprung weight will slightly differ, might not make a noticeable difference on a street vehicle, but still not OK. First step, get the wheels off the car and check the backs. Then, once you know if OEM or not, make a decision. Personally I would want all four wheels to have the same mfg, same surface, same weight, and same finish. Also, I would expect a car I bought from a dealer to have all 4 (or 2+2 if staggered) matching wheels, nothing else would be accepted. |
pennsiveguy3552.00 |
10-27-2020, 03:03 AM | #10 |
Rep 645
I think that's what has happened, whether done by the previous owner or by the dealer as part of the sales prep. Kind of bugs me now as the rest of the car is A1 condition. I don't know whether to make a deal out of it and ask for two new wheels or just accept it as the dealer may not even have noticed it if the former owner was responsible.
10-27-2020, 03:37 AM | #11 | |
Rep 2,995
10-27-2020, 10:02 AM | #12 |
Rep 11,145
I would ensure all four wheels are OEM to start off with, and not replicas. Once confirmed they are OEM, I'd move on since it's a used vehicle.
10-28-2020, 07:36 AM | #15 | |
Rep 651
Still, I would request all 4 wheels to be the same if I bought a vehicle from a dealer. |
10-30-2020, 09:13 AM | #16 |
Wisdom Searcher
58
Rep 193
Do a search on center cap corrosion. Seems common with this wheel design, we've got it bad on two wheels. Maybe they refinished wheels to clean up?
BLUE HEAVEN
My cars - 2002 Lemans M5, 2006 Interlagos M3 |
11-11-2020, 11:53 AM | #17 | |
Rep 1,062
Drives: F15 xDrive50i M-sport
2017 F15 xDrive50i M Sport | Superformance GT40 Roush 511 IR FE
