11-06-2020, 07:27 AM | #1 |
Rep 374
Looking for first M3, what do I need to know?
Beginning to look for my first F80 M3 6MT (2015-2018) instead of another F30 340. Obviously there are many differences, upgrades, draw backs which are easily searchable, but I'm looking for any insight on what may not be as known. I'm very familiar with the 3 series platform when it comes to the 340 and B58, but this is another beast. Thanks in advance for any input on what to look for or avoid.
11-06-2020, 07:49 AM | #2 | |
Rep 408
1) Verify the 1200 mile rear differential fluid change. BMW CPO F80's considered this mandatory. 2) Coolant expansion tanks tend to weep/leak. Check for white residue along the seams. If you're lucky to find a later year build date dealers should cover it. If not, it's a very basic DIY 3) Charge Pipes are plastic and are commonly upgraded to either aluminum or silicone pipes for durability. That's all I have. Good luck, they are fantastic cars that have a lot to offer. |
niquehawk547.50 |
11-06-2020, 07:53 AM | #3 | |
Rep 374
11-06-2020, 08:00 AM | #4 | ||
Rep 408
M3 expansion tank - Is this normal? https://f80.bimmerpost.com/forums/sh....php?t=1632966 |
11-06-2020, 08:29 AM | #5 |
Rep 4,709
I haven't seen the charge pipe being a common issue. People will tend to upgrade those as they mod their cars though for piece of mind.
If you are buying a tuned or previously tuned M3, I'd check if the owner did anything regarding the crank hub since that failure seems to be a big topic on here. |
niquehawk547.50 2011ninja3414.00 |
11-06-2020, 09:09 AM | #6 | |
Rep 374
11-06-2020, 10:19 AM | #7 |
Rep 1,669
+1 on crank hub for tuned cars. Not sure if it's an issue for stock cars.
I just bought a 2018 F80 6MT. Be patient to get what you want, but be ready to pull the trigger quick when a good one pops up.
18' F80 6MT, 991.1s cab PDK, F83 6mt, 996 C4S cab 6mt, F30 328iM 6mt
E60 M5 SMG, E39 M5, E46 M3 cab 6mt, E36 M3 5mt |
11-06-2020, 10:31 AM | #8 |
Rep 374
I have until May/June 2021 before I really "have to" have something, so I will have some time before I have to start settling for different colors/mileage/options/etc. I really need to do more research on what options are available, people think are necessary vs nice to have vs never use. My last two I went out of state.....whatever is necessary when you find the perfect ones. Thanks.
11-06-2020, 10:33 AM | #9 |
Rep 3,308
1.) a number of them left the factory flawed with only have two peddles. Confirm the 3rd one is there.
2.) don't put your money down on any model that starts with G |
11
11-06-2020, 10:41 AM | #10 |
Rep 4,988
1. Make sure it had the 1200 mile check
2. Upgrade the charge pipes 3. Put some Michelin PS4S tires on 4. Enjoy Also consider: stage 1 tune (but read up on the crank hub issue), and down pipes
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
niquehawk547.50 YKIGI248.00 |
11-06-2020, 10:42 AM | #11 |
Rep 374
11-06-2020, 12:23 PM | #13 |
Rep 117
i just recently purchased a manual F80 myself. I think the basic rules of buying a used car applies for this one. Things like the crank hub, charge pipes etc aren't a large deal for a mostly stock/oem car driven by a non-aggressive driver. That level of security or concern is dependent on the person.
I'm glad I got the 6 speed. The car driving around town is already pretty easy and numb as it is already, DCT would have diluted the experience even further.
Danny
Bay Area, CA |
11-06-2020, 12:56 PM | #14 | |
Rep 374
11-06-2020, 02:12 PM | #15 | ||
Rep 1,669
Dumped the clutch at 4K and giggled my way through an old fashion burn out.
niquehawk547.50 |
11-06-2020, 02:14 PM | #16 | |
Rep 117
Danny
Bay Area, CA |
11-06-2020, 02:51 PM | #17 |
Rep 628
Test drive both a manual and DCT. I used to be in the 6-speed or nothing at all group, but the PDK on a Cayman changed my mind. Made me realize that an auto can be fun to drive. Having come from an RX-7 and the mazdaspeed3 manuals, I ended up finding the shifter on the M3 to be too rubbery and ended up with a DCT and never looked back. The quick shifting and the engine blips are super smooth on the track and quite addicting
McIntoshMotorSports187.00 |
11-06-2020, 02:55 PM | #18 | |
Rep 3,608
Current: F80
Prior: F82, F32 |
11-06-2020, 03:12 PM | #19 | |
Rep 1,669
niquehawk547.50 |
11-06-2020, 05:24 PM | #20 | |
Rep 4,988
11-06-2020, 05:34 PM | #21 |
Rep 433
Re: charge pipes...in addition to these, the top mount intercooler to which the charge pipe connects is known to leak on several cars, which deposits coolant into the engine. People who have had this problem have reported not getting any error codes so they end up unwittingly driving it with no coolant. Check the intercooler coolant reservoir (way back in the engine bay, near the rear edge of the hood). If it doesn't have fluid, have this checked out. Plenty of threads on this.
If you're going 6MT, be aware that turning off auto rev matching on downshifts (in Sport + mode) can only be done on some cars. Based on threads in this forum, it appears that sometime post mid-2017 the software changed to auto rev match in all driving modes. Not sure if manually rev matching is important to you (it is to me!) but if it is, check to make sure no rev match in Sport +when you do your test drive. Good luck in your search. The F8X is a hoot!!! |
11-06-2020, 05:59 PM | #22 |
Rep 129
For the DCT, I don't like the rough shifting on the gear 1/2. I came from an old 525i 6 speed, and the DCT while is much faster, is kind of rough for me.
Definitely spend some more time on both to compare. I have never tried the manual on the F80 (wish I had). When I lease mine, there were identical spec 6MT that I wish I have test drive. Wife prefer the DCT since she can drives it, so I didn't even try the 6MT... Probably need to try the GTS/CS transmission flash... |
