11-11-2020, 03:40 PM | #1 |
Rep 940
brake upgrade conundrum
Hello all,
My brakes are (seemingly) on their last legs so I'm looking to upgrade soon. My budget is around $2000+/-. I already have Bimmerworld stainless steel lines. I daily drive my car (12,500-20,000mi/yr) and plan on attending 3-4 track days per year. Looking for input on the setups I've already thought of, and perhaps other suggestions for what I can do with around $2k. Option 1: E9x M3 Girodisc front 2pc floating rotor kit - $1,100.00 Brake kit rear (OEM, FCP Euro) - $576.86 DS2500 Brake Pads (front & rear) - $373.90 SRF Fluid - $180.00 Brass caliper bushing kit (front & rear) - $120.00 Total = $2,381.36 Option 2: OEM Brake Kit Front & Rear (FCP Euro) - $1,254.09 DS2500 Brake Pads (front & rear) - $373.90 SRF Fluid - $180.00 Brass caliper bushing kit (front & rear) - $120.00 Total = $1,927.99 Option 3+: ??? The obvious upside of going with both front & rear OEM rotors is that they will be eligible for free replacements via FCP Euro's warranty. The Girodic fronts will cost ~$700.00 to replace, and since the rears are OEM they can be replaced for free. Since FCP also sells DS2500 pads they can also be replaced for no cost apart from shipping. |
11-11-2020, 04:13 PM | #2 |
Rep 12,736
option 1 is going to be better, but more costly than option 2. you won't be going through disks too fast with ds2500's, so it would be up to you to figure out if you want to pay $700 about every other year.
option three would be to save a little more money and getting a stoptech st40 kit. bimmerworld has a pretty good deal on them at $2,300 after their discount code that it just makes more sense next to option 1. secondary to that, you can add to it by upgrading to the st40 rear rotors when you budget for a rear kit, and i've been told a huge benefit is rotating pads (which i would love to do, but can't with my bbk). just keep in mind, you'll probably still want to add ds2500 pads for better results. https://www.bimmerworld.com/Brakes/B...l_rotor_type=1
Instagram; @roastbeefmike
11-11-2020, 04:47 PM | #3 |
Rep 1,366
"Option 3" is what I have now and what I would recommend. I originally went with what you're thinking, Option 1 (with StopTech instead of Girodisc rotors) and spent more money ultimately doing what I have now that I should have probably just done in the first place.
"Option 3": - Used Stoptech St40 or St60 Kit - $1100-1500 (this will vary, but I have seen a few used kits sell this time last year in this price range) - Rebuild kit (New Seals and Dust boots) - approx $100 - Optional - If you want to get fancy, $200 to repaint or powder coat those calipers a color of your choice. - FCP Euro Rear Rotors - $576.86 - SRF Fluid $180 - No need for brass caliper bushings with this setup imo All-in: Approx $2500 I know, over budget. But still a good 3rd option. roastbeef's rec of getting the new ST40 with the Bimmerworld BF sale coming up is also a good one. And would put your total at closer to $3,000 but would still be a solid long-term setup. Just don't be silly like me and buy this stuff twice
#ladydriven Heavy-spec M3 // KW Clubsports // AA x-pipe // Gintani muffler // Macht-Schnell intake // Gintani tune // OMP Seats // Too Many Apex Wheels // Stoptech ST-60 // Cobalt Friction brake pads |
11-11-2020, 04:51 PM | #4 |
Rep 12,736
another thing i forgot to mention is if you do go with that stoptech kit, slap the cheapest oem spec rotor you can find in the rear. rears last a long time, and it will probably last until you're ready to upgrade the rears.
11-11-2020, 05:04 PM | #5 |
Derbo Tuning
3612
Rep 3,026
Elliot,
Hit me up on IG DM. ST40 kit is well below your budget.
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
11-11-2020, 05:05 PM | #6 | |
Rep 940
11-11-2020, 05:07 PM | #7 | |
Rep 940
11-11-2020, 05:08 PM | #9 |
Rep 12,736
ds2500's will get the job done. i ran them when i started tracking and now i just run them on the street. i've used them as backups before with good results. they are good pads, just know a dedicated race pad is better.
11-11-2020, 05:09 PM | #10 |
Rep 940
Definitely, they seem like they'd bridge the gap fairly well between all-out trackpads and OEM pads.
11-11-2020, 09:35 PM | #12 |
Rep 940
Not bad--did you feel like the setup was lacking in any way? Awesome to hear that they didn't fade to a major extent or anything like that.
11-14-2020, 06:34 AM | #13 |
Rep 75
I am in the process of developing a PROPER OE retrofit kit that has the same overall piston area as the Brembo GT kit, and uses Brembo calipers, but costs about half the price.
PM me if you would be interested. |
Space Fox1042.00 SilverSlug682.00 |
11-14-2020, 06:42 PM | #14 |
Rep 304
Would you be addressing the poor air flow of the stock rotors since those are really the weak point of the OE system, in so much as it pertains to keeping the system from fading with heavy use?
derbo3611.50 SilverSlug682.00 |
11-14-2020, 09:03 PM | #16 |
Rep 12,736
piston area and caliper function is not the problem. the problem is the oem rotor's poor efficiency in shedding heat.
11-14-2020, 09:42 PM | #18 |
Rep 940
Purely going for function at this point, don't really care about looks. Same could be said for the rest of my car, I'll have $10k into my suspension before I do a single cosmetic mod.
11-15-2020, 04:30 AM | #19 | |
Rep 75
M. |
6ixSpd6030.50 SilverSlug682.00 |
11-15-2020, 08:55 AM | #20 | |
Rep 3,412
With the repurposed calipers, brackets, lines, and a two piece floating rotor (of similar specs to existing BBK) what would this save?
Not a Doctor, those are just my initials.
11-15-2020, 11:08 AM | #21 | |
Rep 75
- Are primarily marketed at ppl caring more about looks than performance - Use cheap, easily available, often heavy calipers without much thought into piston areas, pedal travel/feel or master cylinder compatibility - Use caliper designed for much thicker discs, but are marketed for stock discs - Expect you to retain stock discs, which are a weak point (heavy, not very tolerant to abuse) and the 1st thing I'd change - Are mostly front kits, with no attention to the rear I want a kit that is 100% equivalent to the Brembo GT kit, with no compromise, but without the silly price tag. A caliper is a VERY simple piece of engineering, with very little to it. Brembo are just using their brand position to hike up their prices in a near monopoly position. Through months of research, calculations and refinement, I have therefore now specced a kit that: - Uses high spec Brembo calipers from a high end sports car - Upgrades both the front AND the rear brakes - Has the same piston area and F/R bias as the Brembo GT kit - Uses larger 2-piece discs all round - Doubles the available pad area compared to stock - Requires no butchering/machining of the caliper body to fit - Is HALF the price of a new Brembo GT kit with no downside or compromise Hope that helps understand the value proposition and benefit. Last edited by Captain Caveman; 11-15-2020 at 11:15 AM.. |
