11-23-2020, 07:34 AM | #1 |
Rep 1,669
I've been doing some searching and haven't found much on the topic. I'm wondering if it's less common on the F80.
I had a UUC on my E46 M and liked that it was a bit lower and shorter throws. Also nice snick action. Ran an OEM ssk on my 996. Loved the feel of that too. Seems like Ronald at Autoslutions is highly regarded. Also UUC. Any input on the topic? Curious about DIY install too.
18' F80 6MT, 991.1s cab PDK, F83 6mt, 996 C4S cab 6mt, F30 328iM 6mt
E60 M5 SMG, E39 M5, E46 M3 cab 6mt, E36 M3 5mt |
11-23-2020, 09:45 AM | #2 |
Rep 117
it's probably less common since the F80 is newer than the E46 where that platform is older and more modified at this point.
The improvement you can expect is similar to the other platforms you've had and so is the install. The OEM shifter on bimmers aren't as positive or as good as say your 911 or S2000 etc. If you want it to be more sporty then for sure any of the aftermarket kits are cool. You want to go all the way then CAE, Numeric etc are awesome.
Danny
Bay Area, CA |
11-25-2020, 07:58 PM | #3 | |
Rep 102
Adcampo890.00 |
11-27-2020, 06:57 PM | #4 | ||
Rep 39
http://www.autosolutions.info
2018 F80 M3 YMB 6MT ZCP 2005 E46 M3 Silver Gray 6MT ZCP (sold) |
Adcampo890.00 |
11-27-2020, 08:26 PM | #5 | ||
Rep 102
11-28-2020, 02:42 PM | #6 | |||
Rep 1,669
11-28-2020, 05:44 PM | #7 | ||||
Rep 102
Adcampo890.00 |
08-03-2021, 12:36 PM | #8 |
Rep 354
Reviving this thread! I'm about to embark on the same journey and have read several past threads that you have to lower the exhaust, remove the heat shields and a bunch of other stuff as well. If I'm understanding this correctly you were able to install the SSK from the top without doing all that?
08-03-2021, 01:49 PM | #9 |
Rep 3,645
^ thats my main holdup. there is quite a bit of work involved with some of them. the UUC shifter requires you to drop the transmission. i'd only take it to a reputable shop that has done a few already.
08-05-2021, 03:13 PM | #10 | |
Rep 23
It's not that big of a deal, don't let that hold you back from installing a SSK. |
Jamongkad239.00 |
08-05-2021, 03:29 PM | #11 |
///M Powered for Life
11502
Rep 10,334
Another vote for the AS SSK, it is the real deal
You will have to get under the car to install it, there's no way around it. Maybe if you have the little hand from Scary Movie 4 (?) you can do it all from the top |
08-05-2021, 03:47 PM | #12 | ||
Rep 354
08-05-2021, 09:33 PM | #13 | |||
Rep 23
08-05-2021, 09:54 PM | #14 | ||||
Rep 354
08-06-2021, 09:12 AM | #15 | |
Rep 358
Drives: 2017 BMW M3 ZCP
Garage List 2001 Honda S2000 [0.00]
2006 Mini Cooper JC ... [0.00] 2020 Audi SQ5 [0.00] 2017 BMW M3 Competi ... [0.00] |
08-06-2021, 09:44 AM | #16 |
Rep 23
Unbolt the transmission support brace only. It will drop the tranny/driveshaft down a couple of inches to give you clearance.
08-06-2021, 09:48 AM | #17 | |
Rep 23
https://f80.bimmerpost.com/forums/sh....php?t=1822447 I also linked which tutorials I used on similar platforms. |
Jamongkad239.00 Soul Coughing257.50 |
08-06-2021, 12:51 PM | #18 |
Rep 432
I also got Ronald@Autosolutions as a recommendation for the SSK. Speaking to him last week, he indicated that there would be a 60 day pause on manufacturing due to his company moving shops. The one thing that I didn't realize was the Autosolutions SSK is a fully custom product. Ronald has an intake form where he asks you about your use case. He can fully custom all the overall height and ratio reduction.
08-07-2021, 08:58 PM | #19 | |
Rep 354
08-09-2021, 06:51 PM | #20 |
Rep 1,427
Drives: '23 i4 M50, '15 M3, '18 911
I had a custom job done by Ronald at Autosolutions built for my F80. Went over what my use case was and what my options were. Before that I had him do one for my E46 M3 as well. His shifters are awesome!
Jamongkad239.00 |
