12-06-2020, 07:04 PM | #1 |
Rep 4,178
Rear Spherical Bearings Conversion on Stock Arms
This info was collected from various sites and I am just posting it here for reference. Most of the engineering was done by vtl and fe1rx on 1addicts. You can read their full threads at the links below (very informative reads!):
vtl - https://www.1addicts.com/forums/show....php?t=1302309 fe1rx - https://www.1addicts.com/forums/show....php?t=1615006 The stock M3 suspension retains rubber bushes in various locations. These can be replaced with the parts listed in the table below to get a rear suspension with spherical bearings while using stock arms. This would be a good medium between stock suspension vs full race arms (SPL, Turner, etc) while still being relatively maintenance- and noise-free with sealed OEM-style bearings. Parts Required A. 1x BimmerWorld Rear Camber Arm Bearing Kit: https://www.bimmerworld.com/BimmerWo...aring-Kit.html B. 8x Lemforder 3067901 or Meyle 3147100005 bearings C. 4x custom tapered washers (Pic by vtl) Item C (tapered washers) go in these locations (marked in red): Item B, needs to be installed offset 3mm to allow space for Item C. (Pic by vtl) More details on installation of the guide rod and wishbone bearings with tapered washers here: https://www.1addicts.com/forums/show...&postcount=293 Tapered washer designed by vtl: Disclaimer - I'm posting this info for reference. I am still collecting all the parts required to do this conversion so I can't comment on complexity of the job. Will post details/reviews here as I do this mod later. Edit 16Nov2023 - Custom tapered washers are available for sale from spikenipple . Email him at: ow_dont_pull_that@hotmail.com Last edited by Redd; 11-15-2023 at 06:00 PM.. |
12-06-2020, 07:17 PM | #2 |
Rep 4,178
I have 8 sets of tapered washers available for sale here at USD30 per set of 4 washers.
https://www.m3post.com/forums/showthread.php?p=26987547 |
derbo3611.50 |
12-06-2020, 10:20 PM | #3 |
Rep 1,055
I'm pretty sure the guide rod and wishbone on the M3 uses spherical ball joints at inner and outer locations from factory, no need to replace these unless worn. If they are worn, prob easiest to just replace with oem arms which will have the spherical bushings pre-installed.
M3SQRD2347.00 |
12-06-2020, 10:29 PM | #4 | |
Rep 4,178
derbo3611.50 |
12-06-2020, 10:57 PM | #5 | |
Derbo Tuning
3612
Rep 3,026
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
12-07-2020, 12:28 AM | #6 |
just another M3
514
Rep 1,152
Where to purchase the bearings tho.
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
12-07-2020, 01:27 AM | #8 |
Rep 3,007
Looks good, any idea if when replacing the bushings to bearings should I buy a new part to do it or modify the original ones on my car?
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI |
12-07-2020, 02:35 AM | #9 |
Rep 4,178
My arms were 130k kms old, so I got new OEM TRW arms and will be installing the bearings into those. If your car is low mileage I suppose you can re-use the original arms.
12-07-2020, 08:29 AM | #10 | |
Rep 1,055
My apologies! Wow, washers went quick.
12-07-2020, 09:05 AM | #11 |
Rep 4,178
12-07-2020, 04:28 PM | #13 | |
Rep 3,007
I find it funny how we are swapping non-m bushings in an M car now. When all the other non-M guys are trying to swap in M3 stuff.
12-07-2020, 06:48 PM | #14 |
Rep 4,178
12-08-2020, 11:04 AM | #15 | |
Rep 542
To add to this I have done 1 and 2 in the table above using this bavauto tool It made the job a walk in the park . https://www.ecstuning.com/b-bav-auto-tools-parts/trailing-arm-bushing-tool-set/b8800101~bat/ |
12-08-2020, 08:33 PM | #17 |
Rep 1,597
Very cool. Thanks for posting!
Great option for those who haven't upgraded to full spherical rear arms and want the performance benefits but at a more reasonable price and maintains that 'stock' appearance when looking under the car. |
CTMike262.00 |
12-08-2020, 10:34 PM | #18 | |
Derbo Tuning
3612
Rep 3,026
I like that we are replacing the rubber bushing with an OE Spherical bushing regardless if it is M or not.
IG:ruhrohz_m3
12-09-2020, 02:19 PM | #20 |
Rep 2,672
Redd thanks for sharing all of this, very cool!
Just when I thought I was done with my suspension setup
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
12-09-2020, 03:31 PM | #21 |
Rep 3,007
its never done.
12-09-2020, 06:16 PM | #22 |
Rep 4,178
