12-22-2020, 03:09 PM | #1 |
Rep 102
Storing M and battery
Quick one guys. I’m about to store my M3 for next few cold months. Can I remove the battery to bring it inside/charge? Or will it need to be coded come next spring?
I would rather not go through the hassle of coding/registering the battery so what’s the best way to keep it in good health through winter? Thx |
12-22-2020, 04:09 PM | #2 |
Rep 801
Yes and no.
It's not actually "coding" a battery. You're just telling the car that it has a new battery so that it will charge it like a new battery, rather than an old one. (I think the real intent was to encourage service visits - it's not like the E9x gets meaningfully different battery life than previous cars.)
2011.75 E90 M3 | 2006 GMC Sierra LBZ | 2004 X5 3.0i 6MT | 1995 M3 S50B32 | 1990 325is | 1989 M3 S54B32
Hers: 1996 911 Turbo | 1989 325iX |
12-22-2020, 06:00 PM | #5 |
Rep 237
You can disconnect the battery on negative terminal.
You can remove it and bring it inside. You can put it on a battery tender (not the same as trickle charger) from under the hood terminals. Either way works, obviously the very best option is to bring it inside and connect it to a battery tender. Since it's a big chore to remove the battery, I connected a battery tender under the hood. Also no re-registration of battery needed. You do that when it's replaced with a new one. |
94jedi832.00 |
12-23-2020, 12:22 AM | #6 |
Rep 7,129
Like ha9981 says, no issues to disconnect (+re set the modules properly...). Personally would leave the battery in the car. Fully charged (!) it doesn't have issues with cold temperature.
Ps. "Coding" only needed when replacing with another spec battery. |
12-27-2020, 08:03 AM | #7 |
Rep 1,254
If you have access to electric, just put a ctek battery tender/charger on it.
2009 E92 M3 build thread: https://www.m3post.com/forums/showthread.php?t=1754875
Follow me on IG - www.instagram.com/the_driven_enthusiast |
12-27-2020, 08:44 AM | #8 |
Schumacher
791
Rep 2,282
Drives: E30 325is,E93 M3,X7M50,F06 M6
Where are you storing it? I would put on a battery tender, that's what I do every winter. No issues after 7 years.
12-29-2020, 09:46 AM | #10 |
Rep 801
No. It'll be the same old battery. No need to register it.
12-29-2020, 09:49 AM | #11 | |
Rep 801
Once you've seen a battery tender boil over or blow up a battery, you get a lot less enthusiastic about this. And to be clear - I have a CTEK. It's fine, aside from the extremely unreliable button. I also have "battery tender" brand tenders, and a larger scale charger. I'd much rather charge the car for a day every 3-4 weeks than leave it plugged in continuously.
12-30-2020, 08:47 AM | #12 |
Save the manuals!
6031
Rep 6,753
I've never had any issues with CTEKs or battery tenders plugged in 6 months at a time on multiple cars for the last decade. It's extremely common up here.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
12-31-2020, 02:00 AM | #13 | |
Rep 7,129
