12-25-2020, 02:04 PM | #1 |
Rep 428
Reuse reinforcement plate bolts?
So I think I dropped a oil filter housing bolt down there and have had no luck sweeping with a magnet. Plus I’d like to remove it to clean the oil mess and drain the block.
Can the bolts be reused? I know it was removed for RBs, not sure if they replaced them when they did the job. Merry Christmas! |
12-25-2020, 10:15 PM | #2 | |
Rep 2,145
Drives: 2011 E92 M3
Cheers,
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
ha998193.50 |
12-29-2020, 06:07 AM | #3 |
mTekMods
2161
Rep 2,912
safe to be reused as they are steel bolts.
12-29-2020, 09:45 AM | #4 |
Rep 801
Yes, you can reuse them. Note: They are already stretched. Do not follow the factory angle torque sequence!
2011.75 E90 M3 | 2006 GMC Sierra LBZ | 2004 X5 3.0i 6MT | 1995 M3 S50B32 | 1990 325is | 1989 M3 S54B32
Hers: 1996 911 Turbo | 1989 325iX |
12-29-2020, 11:28 PM | #5 |
Rep 860
so if you're not using the factory re-torquing spec of 56nm + 90*, what target are you torquing to? In the end 56 + 90* doesn't end up being 56Nm if you were to reuse the bolts. According to the data log from when I last did the plate bolts the 56NM + 90* ends up at roughly 89NM applied at the end of torquing.
I used new bolts. I wouldn't feel safe doing that to used bolts. It feels like they are ready to snap.
01-04-2021, 09:02 AM | #6 | |
Rep 801
That said, I'd probably torque them to about 50ft-lbs reusing.
