01-03-2021, 01:05 PM | #1 |
Rep 4,252
Drives: 2017 M3 MG/SO ZCP DCT
Any one on here use dollies to move their M3s around the garage?
I'd like to slide my E92 left to right to open up some floor space with out having to back the car in and out every time I want to move it. These I found have 11" max width which is 279mm so 265 rears should fit but may get pinched if not perfectly lined up. Also the 285 rears on the F80 probably wouldn't fit if you wanted to use it on a newer car. Appreciate any thoughts or experiences with these devices. I did a search here and didn't find any old threads but please link those if I missed them. |
01-04-2021, 08:45 AM | #4 |
Rep 801
Cheap dollies without integrated jacks may be easier to use. Generally no width limitations on them.
If the goal is winter storage (aka very occasional actual use), I'd go with dollies that have as few features as possible. The built in jack types are nice if you use them a lot, but add points of failure and bulk if you don't. (In particular, do you really want to be catching your ankles on those wheels / jack handle?)
2011.75 E90 M3 | 2006 GMC Sierra LBZ | 2004 X5 3.0i 6MT | 1995 M3 S50B32 | 1990 325is | 1989 M3 S54B32
Hers: 1996 911 Turbo | 1989 325iX |
IB M2790.00 |
01-04-2021, 06:08 PM | #5 | |
Rep 4,252
01-05-2021, 12:45 AM | #6 | ||||
Rep 85
04-20-2021, 02:30 PM | #7 | |
Rep 3,412
Not a Doctor, those are just my initials.
04-20-2021, 10:41 PM | #8 | ||
Rep 4,252
04-21-2021, 06:31 AM | #9 |
Rep 954
I used the ones from Harbor Freight, just a basic dolly and any size tire will fit. Had them under my E36 M3 when she was down for a couple years, made it super easy to move it around the garage. Also had them under my last Mini after it popped a HG and had no problem moving it around on my own. They are cheap too!
IB M2790.00 |
05-15-2021, 04:31 PM | #10 |
Rep 3,412
Picked these up. Overall huge success to recovering space in my garage while the car sits between track / maintenance days.
Now, whoever is responsible for distributing a single dolley at each respective store should be fired. What sense does it make for everyone to have only 1 in stock? Spent a couple hours driving around snagging one at a time. The rear tire is 12.32", 305/35/18 NT01. No issues with clearance even though they're spec'd for 11" max width. but this is likely the largest tire width I'd run. Lastly, huge improvement to pulling this in / out of the garage with aero. Don't have to Austin powers my way back and forth to try and create space while watching that wing and splitter.
IB M2790.00 |
