01-17-2021, 08:49 PM | #1 |
Rep 684
Anyone diy TPMS on 19's
My rule of thumb, anytime I'm doing maintenance I like to replace any consumables I can if I'm in the area and it makes sense. I got new tires installed and was to excited any to lazy to run back home and pick up the sensors to have the shop install them. Do I took a gamble. Guess what went out 1 week later?
The shop will do it for me for pretty cheap but I'd have to schedule it and My schedule is just to crazy to afford the time during their business hours. I've done them before on my truck wheels with the harbor freight bead breaker tool with little issue but I'm not sure if I'd have the same easy time with the competition 19 inch wheels. Just curious if anyone has diy'd them? -Mark |
01-18-2021, 08:39 AM | #3 |
Rep 684
im sure that would require coding and if i'm gonna go through the trouble of that then Id prefer to not have a tire monitoring system at all.
id rather take the risk of not having any system as i've had the monitoring systems fail me far more often then an actual pressure drop. |
01-18-2021, 03:04 PM | #4 |
Save the manuals!
6032
Rep 6,753
That's precisely what FTM is for.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
mym3adventures176.00 |
01-18-2021, 03:34 PM | #5 |
Rep 10,666
Might be tough to break the bead DIY. I’d pay the shop.
LakeSurfer821.00 |
01-18-2021, 03:47 PM | #6 |
Rep 3,332
Don't do it. You're just asking to destroy your rim. A giant truck bead with a big sidewall has far less tension than a 35 profile tire.
A tire shop should be able to get you in and out in under an hour. If your schedule is that crazy then just wait and drive with the TPMS on - it's not going to impact anything other than it being annoying.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
01-18-2021, 11:06 PM | #8 |
Rep 833
Instead of using sensors (TPMS) in each wheel, FTM (flat tire monitor) uses the already existent wheel sensors on each corner to read pressures. Paying a coder to code in FTM is cheaper than fiddling around with TPMS, especially if you have multiple sets of wheels.
https://www.m3post.com/forums/showthread.php?t=1487472 |
01-19-2021, 08:49 AM | #9 |
Rep 942
^ oh I need that! Thank you. I have 3 sets of wheels. Do you happen to know someone that can remotely code that our for me? I can unplug the module.
2013 e92 M3
2011 X5 35d 2018 F80 M3 ZCP |
01-19-2021, 03:50 PM | #11 |
Rep 7,129
Don't believe the M3 ever had TPMS as an option over here, weird. On the other hand FTM comes as standard, saved my 359 rim once so does the job I guess.
01-19-2021, 09:26 PM | #12 |
Rep 10,666
There must be highly TPMS paid lobbyists in the US if it really has not necessary because the computers can be coded to use existing sensors instead. Would not surprise me since politics here is unfortunately overly influenced by money.
01-19-2021, 09:39 PM | #13 | |
Rep 3,994
In Canada cars also had FTM. |
01-19-2021, 10:29 PM | #14 | ||
Rep 833
DL335D581.00 |
01-20-2021, 08:51 AM | #15 | |||
Rep 684
-Mark |
