01-17-2021, 09:30 PM | #1 |
Rep 2,819
Drives: e82 1M, f87 M2cs
Stoptech Trophy Sport install
I learned the hard way that increased horsepower and a square setup with R-comp tires will destroy OEM sized rotors. I had hoped that fully floating PFC-V3 rotors would be up to the task with proper pads. I cracked a new set within 5 lapping days. Harold at HP Autosport helped with documentation, but PFC looked at the pictures and determined I had taken them beyond their designed operational temp. No warranty. FWIW, I swapped my OEM rotors back on for the final track day of the season and they held up better. I really don't want to deal with installing and maintaining brake ducts....but if it remains necessary, I will.
I considered the AP racing 372mm front setup with OEM rear, but my rear calipers are showing their age and I would prefer a set-up that comes balanced. Brembo 380mm front set won't clear my track wheels. Stoptech 380mm with ST60 6-pot calipers will. Stoptech it is. As a show of good will (having just bought the PFC rotors this year) Harold gave me a great deal on a Stoptech Trophy Sport BBK, which I finally had a chance to install today. During the bed-in procedure, it became abundantly clear that these stop the car very well. The second set of decelerations were very impressive with no fade even on rep #10. There is no doubt I could autocross with the street pads, something I could not do confidently with the OEM system using OEM pads or PFC Z-rated. I went for another drive this evening and can say enough about the pedal feel. I can't wait to head to the track with the "Club Race" pads. Shout out to HP Autosport for awesome service! Pics: front before and after, front and rear with the 359's, and a closeup following the bed-in....nice blue hue!
1M track toy mods: BMS chargepipe, BMS OCC, ADE FMIC, ADE motor mounts, MadDad/Lightweight Ti exhaust, ADE custom oil thermostat/cooler, custom MHD tune, F10 550i clutch, Ohlins R+T, Vorschlag camber plates, M3 'vert FSB with Turner endlinks, Stoptech Trophy BBK.
01-18-2021, 05:53 AM | #2 |
Rep 56
I was wondering was was your track wheel setup ? I was looking to upgrade my brake a well and Stoptech Trophy were on my list after the PFC BBK got discontinue.
I'm using a 275/35R18 wheel setup with Nitto NT-01 a each corner. |
01-18-2021, 07:10 AM | #3 |
Rep 2,819
Apex ARC-8 18x9.5et22. You can download and print templates from Stoptech to make sure you have enough wheel clearance. They recommend 2mm. I think I have 3-4 mm.
MightyMouseTech4337.50 |
01-18-2021, 09:20 AM | #4 |
Rep 56
I'm currently using Enkei NT03 18x10 et 25 wheels and I'm not sure the 380 mm will fit under them, I checked with the template and it doesn't look like it will fit.
Other choice is to go with the 355mm kit |
01-18-2021, 09:26 AM | #5 |
Rep 2,819
Or consider the AP Racing 372mm front only.
01-18-2021, 01:12 PM | #7 | |
Rep 2,819
Apparently they are no longer doing the bronze anodized finish on the race hats, so I have the old style bronze race hats on the rears and the new style black race hats on the fronts. Fortunately this is not a show car so I really don't care about appearances, but waited about a week before installing because I wanted to verify that I had in fact received race hats, fully floating.
01-18-2021, 01:41 PM | #8 | |
Rep 99
Good info on the hats. Hopefully mine match since mine is more show, lol. But too bad they don't do bronze anymore, as they might have gone better with my wheels. Thanks for the info! |
CarJunkie2618.50 |
01-24-2021, 08:57 PM | #9 | |
Supreme Allied Commander
3888
Rep 54,553
Drives: F80 M3
The 309 prefix sport pads will do good for all around use, including autocross. For track duty you will want something more aggressive like the Stoptech's SRT 32 or 33. Ferodo DS1.11 is also an excellent choice if you want a pad with a super flat torque curve and extended wear characteristics. |
01-24-2021, 08:58 PM | #10 |
3888
Rep 54,553
Drives: F80 M3
07-02-2021, 07:45 PM | #11 |
Rep 441
07-02-2021, 08:06 PM | #12 |
Rep 2,819
I haven't tried installing the 359's without the front spacer, but the kit is marketed for the 1M with no fitment disclaimers, so it should fit stock wheels.
PRTSB1M312.00 |
07-04-2021, 01:25 PM | #13 |
Rep 441
I decided to try a cocktail of StopTech trophy sports up front and Turner TrackSport slotted rotors with StopTech 309 (sport) pads in stock calipers for the rear. Will report back once everything arrives and gets installed in August (hopefully).
07-17-2021, 08:04 PM | #14 |
Rep 2,819
You will probably be fine. I have already used up a set of front pads in 3 track days and the rear pads look nearly new. I am guessing a 3:1 ratio of front pad to rear pad use with the full stoptech setup. Consider using the brass guides in the stock rear calipers. They need a little more TLC, but the prevent angular deflection under hard braking. Pretty cheap mod to make them more robust.
07-18-2021, 10:52 AM | #15 | |
Rep 441
CarJunkie2618.50 |
07-18-2021, 08:45 PM | #16 |
Thread killer
646
Rep 1,896
Just be super vigilant with maintenance.
Although I think the following anecdote relates to the stock -front- calipers, one of the M3post guys had his solid guide pins freeze to the caliper leading to jamming. So just make sure to lube it -often- and definitely before a track day, if you end up doing the conversion. I run an Essex AP BBK up front with stock rears and leave aggressive street compound on the rear (DS2500) for street/track, and swap to race compound up front. This has been a reasonable compromise for me. I do this because I'm lazy and am tired of futzing with having to pull the OEM caliper for pad changes. (Each time I don't strip the caliper mounting bolt or manage not to drop the caliper and stretch the brake line, I feel like I got lucky.) |
PRTSB1M312.00 |
07-18-2021, 08:57 PM | #17 | |
Rep 2,819
07-18-2021, 09:00 PM | #18 | |
Rep 441
