01-24-2021, 08:46 AM | #1 |
Rep 552
Drives: 2014 X5 35d, 2008 Lexus IS-F
Has anyone else experienced this issue?
I was driving back home last night and all of a sudden my 6WB Cluster shut off for like 3 seconds. When it came on, it looked as if I had just started the vehicle, it gave me warnings about the Active Cruise Control (ACC), then went back to how it was before it restarted. Everything working fine and no issues reported with any systems. I was using the ACC when this happened but I was not using any navigation or anything, just listening to the radio. I will run my Foxwell on it this morning but wanted to ask if anyone has experienced this. I did a Google search and only found that other models have had/or are having the same issue and found a a TS as well but no mention of the F15. Also, it only mentions the 6WA, link provided below. Anyone have something on this? https://www.2addicts.com/forums/atta...8;d=1546630821 |
01-24-2021, 11:11 AM | #3 |
Rep 552
Fixed to ACC to ensure everyone understands my concern.
01-24-2021, 11:28 AM | #5 |
Rep 2,523
Since your profile shows 2014, I assume you got 6WB retrofitted so check connections first,see if anything got loose. If physical connections look right-do what CatalinP said- get ISTA and check for any stored errors.
01-24-2021, 11:36 AM | #6 |
Rep 552
It was retrofitted over a year ago. It is the first time this has happened. I guess I better get ISTA and get savy on it then. Thanks
01-24-2021, 12:48 PM | #7 |
Rep 552
Best place recommended to get ISTA from gents?
01-24-2021, 01:54 PM | #8 |
Rep 2,523
Got version 4.24 here https://www.bimmerfest.com/threads/i...links.1397351/
XxBBVTMxX293.50 |
01-25-2021, 04:03 PM | #10 |
Rep 552
Yes. I just ran ISTA as recommended and I did have some memory errors and the KOMBI was one of them. I deleted all memory errors, disconnected and restarted ISTA and the F15, ran it again and all is green now.
My 6WB was retrofitted over a year ago and this is the first time I've had any issues with it. Everything is working normal with no issues after that restart though 🤷🏽 |
11-19-2023, 12:30 PM | #11 | |
Rep 199
11-19-2023, 12:35 PM | #12 | |
Rep 552
But no, no issues 🤙🏽 |
