01-31-2021, 06:40 PM | #1 |
Rep 290
Aftermarket warranty for RB and TA work?
Question for those experienced with aftermarket warranties on these cars- have you used them to get the RB and TA work done under the warranty? Is it possible to do that if there hasn't been a failure? If you have specific intel on a CNA warranty, that's even better. Thanks.
01-31-2021, 06:49 PM | #2 |
Rep 140
Throttle actuators are easy and will be covered under any company that has coverage for Throttle bodies, however, they will only replace one side at a time as they only replace parts that have failed and usually require proof/fault codes. That brings me to the next point, I have never had a rod bearing replacement covered as they need to "fail" first and show symptoms (rod knock / noise.) At that point, the motor would be toast and most places have a maximum payout (usually ~$6500-7k) which would leave the rest of the motor replacement out of your pocket.
Source : GM at a BMW/Merc Indy |
01-31-2021, 07:06 PM | #3 |
Rep 1,076
Save the money used to buy a warranty and use it to replace the RB as preventative maintenance. The S65 is a pretty solid engine with typical BMW gasket weepage that many times isn't even covered.
01-31-2021, 09:54 PM | #4 | |
Rep 950
02-01-2021, 12:53 AM | #5 | |
Rep 290
Thanks everyone, I had a feeling it would be as easy as that to get them covered. Question, so with the above in mind, would you go for a later year/higher mileage ('12/80k) M3 that had the RBs done over an older/lower mileage ('08/55k) one that didn't have the service but has a warranty? I'm thinking yes. |
02-01-2021, 03:37 AM | #6 | |
Rep 950
02-01-2021, 09:22 AM | #8 | |
Rep 290
Thanks...appearance doesn't seem to be that different, tech for sure. |
02-01-2021, 07:08 PM | #9 | |
Rep 290
UGH, such a tough call! |
02-01-2021, 07:33 PM | #10 |
Rep 361
I would go for the lower mileage 08 personally.
The tech is easy to upgrade from a newer car. I did my CIC Navigation upgrade for under $500 with bluetooth streaming (combox). If you want the new style LCI tail lights those can be swapped as well. With those two things, it will be nearly identical to the 2012 feature wise. |
02-01-2021, 08:53 PM | #11 |
Rep 950
I have an '08 and love it. I actually prefer the style of the rear. I like the benefit of being able to detect metals in the old bearings via oil analysis, and yes I know that isn't a fool proof or guaranteed approach to managing the rod bearing issue.
I do miss the CIC, not any particular features, it just has a more up-to-date look. As others have suggested, AVIN android or similar install took care of that issue. I'm still an AM/FM guy so it really doesn't matter. I think the '08 with 55k and a warranty it the WTG. Good Luck. |
02-01-2021, 09:33 PM | #12 |
Rep 290
Also...08 is sunroof, all OEM...'12 is slick top, several go-fast/stop-fast mods. Now a $3,000 diff between the two. Any change of opinion with that?
02-02-2021, 12:43 AM | #13 |
Rep 6,638
02-02-2021, 12:56 AM | #14 |
Rep 290
02-02-2021, 09:22 AM | #15 | |
Rep 973
Drives: 2012 E92 M3 DCT ZCP
But I have never seen an aftermarket warranty cover RB replacement preemptively, so I agree it's worth spending the money on it as preventative maintenance.
2012 E92 M3 | ZCP | DCT | Space Grey Metallic | Black Novillo | BE/ARP | MPE V2 | AA green filter |BMW CF Rear Spoiler, RW Carbon Diffuser, CF Front Splitters | DTEC 160W Angel Eyes
02-02-2021, 09:59 AM | #16 | |
Rep 290
02-02-2021, 10:17 AM | #17 | ||
Rep 3,412
On the bright side it's a relatively small investment (2 floor jacks, 4x high quality stands, basic metric socket sets, and a good quality impact driver). You can almost all the work on these with endless YouTube videos and forum DIYs as a reference. If you don't have time, then yes a reputable warranty should pay dividends but you're likely waiting for shit to break vs preventative.
Not a Doctor, those are just my initials.
02-02-2021, 11:38 AM | #19 | |
Rep 973
The diff probably could have been replaced with a good used one for less, but that's a pretty unlikely failure on these cars, and since it was covered by the warranty, I was happy to get a new one! Besides TA's and RB's, these engines are pretty solid and reliable. TA's are not a difficult DIY. I did one of my own last Sept.
02-02-2021, 11:55 AM | #20 | |
Rep 1,076
PACarGuy686.50 |
02-02-2021, 01:28 PM | #21 | ||
Rep 6,638
02-02-2021, 02:27 PM | #22 | |
Rep 973
I can do basic stuff and do as much as I can (TA's, fuel breather valve, fluids, basic maintenance, etc.), but there are certain repairs I don't have the desire, patience, guts, time or tools to tackle for fear of really screwing it up and stranding the car in the garage, or breaking something more expensive, LOL. The local indy gets those...
