02-02-2021, 07:22 PM | #1 |
Rep 538
How low is too low of ethanol percentage?
Getting e85 tune and wamt to make sure the quality is good enough before i make the commitment Also should i get a flex fuel sensor? |
02-02-2021, 07:37 PM | #2 |
Not willing to take advice
4105
Rep 1,529
Actually - good question. I have an E85 tune for my Audi S4, which I've always noticed that certain places throw the CEL after filling. Over time, I just realize which locations these were...and avoided (found a couple good placed that I use solely).
I see that Amazon has test kits you can get - but would be miserable trying to test this from the pump. Assume testing is really the only way to tell what you're getting?
Proud owner of 4 Turbos and 1 Supercharger
m4h2o288.50 |
02-02-2021, 08:10 PM | #3 |
Rep 5,188
A mild pump E85 tune is usually geared for 77-85%. A hotter tune would need 80% minimum.
Since E is a good drive away I bring a few gas pails to bring home, so pump testing is a must. Yes, testing at the pump is a pain in the ass, but better than filling with 75% and finding out when you stomp it. Get either the bigger gasohol tester that fits a gas nozzle in (easier but wastes a little more) or get the tiny gasohol tester vial and bring a clean glass bottle to pour from. I bring my little tester with the water already in it so testing is quick, but I use a Pipette to add my E from jar to tester. I don't care if some people stare...racers know what I'm doing and sometimes ask the %. If you're mixing E50 or E30 then knowing your pump E% is important, otherwise your tank E%will be off.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
McBobby Jr212.00 |
02-02-2021, 08:20 PM | #4 | |
Rep 1,977
papasmurf_m3454.50 |
02-02-2021, 08:20 PM | #5 | |
Rep 538
Im hearing the winter blend is around 70. So i guess i should stay away from it? |
02-02-2021, 08:21 PM | #6 | |
Rep 1,977
https://f80.bimmerpost.com/forums/sh....php?t=1782025 |
02-02-2021, 08:26 PM | #7 | ||
Rep 538
Understanding this correctly the ff is a tune? So i wouldnt need the actual sensor? |
02-02-2021, 08:27 PM | #8 |
Rep 1,397
Flex fuel tunes still require input to make fuel trim and timing adjustments. This requires the sensor, regardless of who the tune is from. Ecutek and mhd are currently available where bm3 is NOT.....
02-02-2021, 08:32 PM | #9 | |
Rep 538
Out for bm3 or do you think thise are 2 are reputable enough? |
02-02-2021, 08:51 PM | #10 | |
Rep 538
02-03-2021, 03:35 PM | #11 |
Rep 3,646
thats why im not touching e85 until a flex fuel tune comes out for my bm3. Had a flex fuel tune with GTR which makes life alot easier... you can throw in whatever mix of 93, e60 and e85 you want.
2018 Porsche GT3 6MT 2021 M2C DCT Previous: Ferrari 458 | R35 GTR | F80 M3 | E46 M3 | E36 M3 | Scion FRS |
02-03-2021, 10:53 PM | #12 |
Rep 844
That does sound like a horrible PITA Go flex fuel with ecutek. You will thank yourself. I just pour in anything and go. Doesn't matter you have maximum power in any situation. No limping home testing flashing at the gas station.
60-130 mph 6.72 secs
1/2 mile trap speed 158 mph ecutek - bend calibration pro tune - flex fuel - mpe - stock turbos - oem+ |
TacoJova73.50 |
