02-03-2021, 06:02 PM | #1 |
Rep 428
I got a schroth quick fit from a forum member, new in the box.
I'm having an issue with how it came assembled. The install is supposed to be a metal bracket to the seatbelt mount in the left side of the drivers seat which then clips to the left side of the Schroth lab belt with a caribeener style latch. My harness came with that caribeener style latch, but it is separate and the harness itself has a female seatbelt receptacle there. Am I somehow supposed to remove the left lap belt section that has an unusable female receptacle and replace it with the caribeener style hook section? I have pictures but having trouble posting them using Imgur. Anyone dealt with this before? I have verified it is the correct belt for an e90, the DOT tag has that info on there and everything else fits. Thank you!!! |
02-03-2021, 06:20 PM | #2 | |
Rep 818
02-03-2021, 09:03 PM | #3 | ||
Rep 428
In the pic, the carabiner and strap are loose and not part of the whole "assembly". I plan to call HMS and see if they can help, hopefully someone has encountered this. |
02-03-2021, 09:14 PM | #4 |
Rep 2,747
9ers
02-03-2021, 09:17 PM | #5 |
Rep 651
Drives: 2008 Melbourne Red M3 Coupe
Looks like you are missing the anchor for the left side (drivers side). Here is a video I found that might help: Schroth Quick Fit Pro Harness Installation - BMW E90
02-03-2021, 09:21 PM | #6 | |
Rep 428
My problem is the lap belt has a female buckle installed and my carabiner piece is separate. |
02-03-2021, 10:05 PM | #7 |
Rep 428
Yellow arrow - loose belt with carabiner hook
Second yellow arrow is the piece that's mounted on the left side of the driver seat and the carabiner hook is supposed to latch to it. Red arrow - installed lap belt with female buckle The carabiner belt needs to be in place of the female buckle belt. I can't just pull it out and re-thread, there is a black plastic piece in the way and I don't want to break it in case I have to return it. |
02-04-2021, 12:29 AM | #9 |
Rep 4,180
Your harness looks correct as assembled. As SAMM3Y said, you're missing the belt buckle piece that goes on your left side at the original seat belt bottom rail.
I don't know what that carabiner piece is for. |
02-04-2021, 08:48 AM | #10 |
Power is nothing without control
34
Rep 762
I had an E90 Quick Fit before I sold the car. My shop replaced the lap belt w/ female buckle with the lap belt w/ carabiner. I don't know the details but it should be possible because it worked.
Contact Schroth / HMS and they should be able to guide you through it. Another option is to buy an extra tail strap (same piece as the one you put in the back seat) and use that with the harness the way it is. I believe the E92 Quick Fit comes with two tail straps since the mounting point is not on the seat but it's on the floor so you need the extra length. |
02-04-2021, 11:30 AM | #12 |
Rep 2,747
Yeah I think OP has an e90 so might be different and I did a little sleuthing last night and think he needs to switch out the male buckle on the part with the extra female receptacle for the one with the carbiner latch type and install the hook in the sub pack down by the drivers door to latch into? Confusing with out a diagram but it makes sense in my head.
9ers
02-04-2021, 12:25 PM | #13 | |
Rep 428
