02-28-2021, 08:56 PM | #1 |
Rep 1,282
I am trying to code my car after I did trailer hitch install and module. I followed below instructions from another forum member. My car was recently in for service and they update my software to the newest update. I keep getting an error.
I found a ton of posts sprinkled throughout the forums about various individual lines to code for the hitch but the approach that looked most promising for 100% replicating what the dealer would do was: add K235 to the HO-WORT folder and write the FA/FP to car VO-Code entire car Inject the CAFD into the AAG unit via: Connect => Read FA (VO) => Activate FA (VO) => Read ECU(VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD matching from latest I-Level Shown => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE Notes: I went with K235 for coding since this is the code recommended in the official BMW retrofit instructions linked. Despite there being lots of specific per-line coding recommendations in other posts, I VO-Coded the entire car to be safe because I couldn't find a definitive list anywhere of which ECUs would be affected by the K235 addition. Boy did I read a lot about this including all kinds of scary posts about needing a battery charger and bricking the whole car because it might take too long. I did a few test codings and they seemed awfully fast, so I turned off the engine, hooked up ESYS, held my breath, and clicked "code" at the top-level ECU. Coding the whole car only took about 3 or 4 minutes and despite some scary cycling of various sytems accompanied by a few scary but brief errors on the idrive screen, once complete I disconnected, turned off the power completely to the car, turned it back on and all was well! Tested all the trailer lights, confirmed the hitch zoom feature was enabled when in reverse, etc. YMMV and maybe there's some huge risk here I'm overlooking so don't take this as gospel (I'm super new to coding) but the whole-car coding approach seemed awfully safe considering how fast it happened. I do know my copy of ESYS has some memory updates I think (memory is set to 4000 in the launcher), maybe that helps it go faster? After the coding I dumped all the .ncd files and compared them to what they were beforehand and found that 10 ECUs had changed (11 if you count the AAG control unit itself). I feel like this confirms my suspicion that the OEM harness + module may be worth it over an aftermarket harness since so many other ECUs are impacted by its presence (everything from the parking assist to the chasis management module). Impacted ECUs: KOMBI HC2 ACSM DSC2 HU_NBT KAFAS2 ICM ICAM BDC_BODY PMA2
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ |
02-28-2021, 10:18 PM | #2 |
Rep 1,282
Screenshots
03-12-2021, 10:35 AM | #3 |
Rep 1,282
Anyone help me out with this issue?
03-12-2021, 10:56 AM | #4 |
Rep 1,547
Drives: '22 Tesla MY + '23 Tesla MY
PSZData version?
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
03-17-2021, 12:17 PM | #5 |
Rep 1,282
03-17-2021, 12:44 PM | #7 |
Rep 1,547
So this involve updating the entire car with any incremental istep versions ...?
