03-23-2021, 07:29 AM | #1 |
Rep 102
M3 advice
Could anybody help I'm thinking of buy a e92 or e93 m3 just wondering what problems the get I no the rod bearings and throttle actuators are commute anything else to look out for any help much appreciated
03-23-2021, 08:01 AM | #2 |
Rep 3,332
If you have to ask the question I'd suggest bringing the car to a reputable BMW shop for a private party inspection. Let a mechanic look the car over and give you a list of what's wrong.
Otherwise the list of common issues with this car could include: -Leaking Valve Covers -DCT Leaks -Bushings & Suspension Wear -Drivetrain & Guibo wear -General signs of accidents or improper repairs -Smelly AC evaporator -Pull any codes to look for previous issues (which could include previous or recent Throttle actuator failure codes)
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
03-23-2021, 09:28 AM | #4 | |
Rep 192
i will probably be 7k in repairs (indy shop) to get it where i want it to be (including RB's) - so factor that in. ideally buying one from this forum with all of these issues addressed is the way to go - i was just too impatient Last edited by MPizza; 03-23-2021 at 10:41 AM.. |
03-23-2021, 09:54 AM | #5 |
Rep 428
If you can DIY, most things that I’ve dealt with have been pretty straightforward. If you plan on paying for repairs, I’d invest in a well sorted one. They are out there.
Bought mine with 77K miles, RBs and TAs already done. 98K miles now. So far it has needed VCGs, Oil filter housing gasket, and alternator. I did DIY and couldn’t be happier. |
03-23-2021, 10:20 AM | #6 |
Rep 420
Drives: E92 335XI (sold)/E92 M3 (sold)
Besides doing the rod bearings as a PM, my car needed:
DCT Transmission pan Driveshaft Complete DCT transmission swap (faulty mecha - rarest dct trans issue) Thermostat Pulleys Hood latch The heater core needs to either be flushed or replaced at some point Will probably need to do my valve covers at some point down the line. |
