03-26-2021, 11:26 AM | #1 |
Rep 98
2 potentially dumb questions...
1.) How can I tell definitively if a vehicle I am looking at has a backup cam? It has the prem package with Nav, but doesn't say it has a backup cam, whereas another vehicle I am looking at, explicitly mentions it. Couldn't find anything when I decoded the VIN, so I'm just not sure.
2.) Is the individual audio worth it? I love listening to music in the car, so I am wondering if I should be excluding vehicles that don't have the upgraded audio, or if it's something I could retrofit later. The vehicle has low mileage and the interior/exterior color combo I want, but it's not a comp pkg (not sure if that's a big deal) and I have some small concerns over the 2 questions above that gave me pause on pulling the trigger. Any info would be hugely appreciated. Thanks! |
03-26-2021, 11:38 AM | #2 |
Rep 12,736
1. None came with an oem backup cam.
2. Premium sound is worth it and difficult to retrofit. Retrofit would be more expensive and time consuming than holding off for the preferred spec car.
Instagram; @roastbeefmike
03-26-2021, 02:03 PM | #3 |
Rep 98
Thanks roastbeef appreciate the response.
Can you speak to competition package piece. Obviously there's information available online but I'm looking to hear from someone with firsthand experience. I was so pumped to finally find this vehicle so it's bittersweet to hear that the individual audio is worth waiting for, given it's really the only thing keeping me from moving forward at the moment. Definitely don't want to have regrets later though. Cheers. |
03-26-2021, 03:13 PM | #4 |
Rep 1,181
Drives: 2011 E92 M3 6MT ZCP
+1 on the Premium sound, was one of my absolute requirements and it sounds great. Competition package gets you the 359 wheels which are some of the best looking OEM wheels available. Some purists scoff at the package but it was another one of my requirements. All personal taste and what's important to you. I drive with the EDC on the firmest setting almost all the time but it's nice to be able to soften up the ride even just a little.
Low mileage is a big draw IMO though, tough choices. Last edited by timothy2001; 03-26-2021 at 03:19 PM.. |
03-26-2021, 03:42 PM | #5 | |
Rep 12,736
Not a deal breaker since the best part about it is the m359 wheels.
03-26-2021, 04:23 PM | #6 |
Rep 445
Drives: '11 E93 M3 6MT, '08 E92 335Xi
at least be aware that the Competition Package was a $2500 option when new and low mileage examples selling on the major auction sites like Bringatrailer.com and CarsandBids.com typically command a premium price. There are 3 up for auction now on BringaTrailer.com
I'd expect private sale prices to also reflect higher prices as well
Pete
03-26-2021, 04:27 PM | #7 | |
Rep 458
Mine came with HiFi and a retrofitted backup camera (euro option). My 335i had Logic 7, and I found HiFi so unusable that I retrofitted individual audio. It took me about 16-20 hours of splicing, running wire, learning how to code, swapping out trim and speakers, etc to get everything working. It was very difficult. I think the center channel + rear deck speakers are really important and aftermarket amps don't have provisions for those. The jump from Logic 7 to individual isn't big, but the jump from HiFi to L7/ind. is ~huge~. ZCP isn't a big deal, beef is right, 359Ms are the main perk. Backup cams can be retrofitted pretty easily, and it's worth it. I find this to be a pretty difficult car to parallel park and it helps. I can answer any questions about the retrofit and tech questions if you'd like as well. Retrofitting the individual audio ("EPS") to a logic 7 car is not difficult as the amp bracket, 20 pin connector, and MOST Bus integration are the same, where HiFi has none of these. I don't even think you have to code EPS in. EPS parts are expensive however. HiFi is: front LR with tweeter, rear LR mids, 2 underseat subs L7: front LR with tweeter, center channel in dash, rear LR + tweeter, LR rear deck, 2 underseat subs EPS: front LR with tweeter, center channel in dash w/ tweeter, rear LR + tweeter, LR rear deck w/ tweeter, 2 underseat subs EPS has much higher quality speakers (Kevlar weave, integrated tweeters with crossover) and is, IIRC, 700 something watts versus the 400 something on L7. In practice, I don't find a substantial difference. Last edited by chocstraw; 03-26-2021 at 04:41 PM.. |
03-26-2021, 05:19 PM | #9 |
Rep 1,300
Competition package comes with different wheels, EDC and car is 10mm lower than standard M3.
- Like others have said, competition wheels is one of the best looking OEM wheels. I personally love them and is a must have. - EDC, I like it because I can put the car in the soft setting when I'm driving downtown and around the city where the roads aren't the greatest. I can put it in sport mode to stiffen them up when I do track days. You can still get aftermarket coilovers if you're into doing track days but it is not as straight forward as non EDC model. Can't speak about audio as I'm not huge into stereo. I'm happy as long as the speak makes noise when I turn them on. I mainly listen to AM radio to give you an idea how little stereo quality means to me haha. This is strictly personal choice though. My suggestion - go for the lowest mileage one you can find/within your budget. All the stuff you mentioned can be done with aftermarket route. |
03-26-2021, 05:40 PM | #10 |
Rep 2,197
If you found a low mileage car with the exterior/interior color combo you want, personally I would pull the trigger on it. Mileage can't be undone, and color combo would be the most expensive to change. Comp package is easy to replicate and as others have mentioned, if premium sound is important, you can probably achieve better sound for less with some aftermarket bits installed by a professional.
Bake
2011 Alpine White on Black 535i M-Sport 2013 Space Gray on Fox Red M3 Vert |
03-26-2021, 09:32 PM | #11 |
Rep 98
Thanks so much for all the feedback guys, sincerely appreciate it.
chocstraw the window sticker and vin decoder just say Hi-fi sound system. I can't find any reference to "Top Hifi" or "Logic 7." so I'll have to guess it's the inferior set-up. I don't have any plans to track the car at this point, it'll just be my daily driver, which really is a misnomer as I am working from home now and will be for the foreseeable future so... recreational driver. The mileage isn't insanely low, but 48k mi. on a 2013 seems pretty reasonable. Clean carfax with zero accidents reported and 3 previous owners. |
03-26-2021, 10:41 PM | #12 |
Rep 445
my Window Sticker lists:
[752] Enhanced Premium Sound $1,900 and my VIN decode shows it as S752 Individual Audio System
Pete
03-26-2021, 10:50 PM | #13 |
Hey, where have you been all my life?
682
Rep 1,400
I always considered the biggest perk of the ZCP package was the carbon fiber roof.
If you add coilovers or springs, defies need for ZCP springs, and the Avant Garde M359's are flow formed alloys that are 2lbs lighter than the cast aluminum OEM 359's. |
03-26-2021, 10:52 PM | #14 |
682
Rep 1,400
I always wished some performance company would design/make a retrofit carbon fiber roof kit with ultralight titanium mechanisms for the E93.
Can you imagine if it were possible to get an E93 lighter than an E92? (With the top down, the center of gravity would at feet level!) |
03-27-2021, 09:29 AM | #15 |
Rep 238
zcp ≠ carbon roof
SilverSlug682.00 |
03-27-2021, 10:39 AM | #16 |
Friends don't let friends ESS
3218
Rep 886
Drives: '11 Lemans Blue 6mt Harrop e90
Garage List 2011 E90 M3 [9.00]
2003 Porsche 911 Turbo [9.75] 2019 BMW X5 xDrive40i [0.00] 2013 Mercedes E550 ... [0.00] |
I have the top premium audio package and I think the sticker on it was about 2300. yes, it is nice. however, with a wireless apple carplay (or android equivalent) upgrade that can include back up camera, plus adding the Bavsound amp and speaker upgrade you can get everything you are looking for for about 2k. It opens up your options to include all cars.
03-27-2021, 11:47 AM | #18 | |
Rep 12,736
zcp is -m359 wheels -slighly higher spring rate and a slightly lower ride height -edc
SilverSlug682.00 chocstraw497.00 |
03-27-2021, 04:38 PM | #20 |
Rep 175
Individual audio does sound really good and I'm not necessarily an audiophile or anything like that. Competition package is nice for all the reasons listed and if resale matters to you it might help later on. If I'm not mistaken competition package also came with carbon leather interior where that could still be an additional option otherwise added but not guaranteed.
Another package that I didn't originally consider when picking up my car that I am now glad I got it is extended leather. It adds an extra touch of refinement to the interior. |
03-29-2021, 11:11 AM | #22 |
Rep 801
EPS sounds *fine*. There is nothing special about it. It's the only E9x M3 stereo that sounds OK from the factory.
That said, it's only fine. The bass is nearly nonexistent (sorry, but there's no subsitute for a subwoofer), treble is bad, etc. Also, you have to mess with the EQ. Set to flat sounds like trash. People are weirdly defensive about EPS, which I just don't understand. Hifi is a simpler starting place if you want to upgrade.
2011.75 E90 M3 | 2006 GMC Sierra LBZ | 2004 X5 3.0i 6MT | 1995 M3 S50B32 | 1990 325is | 1989 M3 S54B32
Hers: 1996 911 Turbo | 1989 325iX |
