03-31-2021, 05:59 PM | #2 |
Rep 12,736
It's going to make sounds regardless after sitting for a while. Ceratec and mos2 have different uses. Read the instructions and use them appropriately.
Instagram; @roastbeefmike
04-01-2021, 03:26 PM | #4 |
Hey, where have you been all my life?
682
Rep 1,400
Hmm Ceratec affecting rod bearing clearance... I haven't heard that, could you cite your source please? I'd be interested in looking into it.
04-01-2021, 09:18 PM | #6 |
Rep 114
I use Ceratec in every single one of my vehicles. I swear by it. I can't see any downsides to throwing in a bottle of it.
ARC-8 Wheels - Stoptech Trophy BBK - Solid Subframe Bushings - Purple Diff Bushings - Topspeed X-pipe - Megan Catback - AFE Carbon Intake - RE Pullies - BPM Tune - GAS Monoballs - ECS Front Sway - GTS Wing - Autosolutions SSK - Vibratechnics Motor Mounts - Revshift Tranny Mounts - VAC Bearings - Bilstein PSS10 Coilovers - Dinan Camber Plates - Ultra Front Strut Bar - BSW Ghost Subs - Matek Diffuser
04-02-2021, 09:02 PM | #7 |
682
Rep 1,400
I think according to the proportions directed on the bottle, one would pour approx 1.5 bottles into the engine oil, and half a bottle into the trans fluid, ya?
04-07-2021, 12:54 PM | #8 |
Rep 5,507
I ran both before (separately) in my M3. There isn't any noticeable difference. I guess you feel better that you have something in the engine?
Auto Detailing Enthusiast!
04-07-2021, 07:16 PM | #10 |
682
Rep 1,400
So I got a response from CeraTec…
"thank you very much for contacting us and your interest in our LIQUI MOLY products. Our Cera Tec is our latest high-tech additive formulation that contains two active ingredients for less friction and wear. It´s designed in particular for use with modern engine designes with tight cleanances, high rpm, high temperatures and high pressure. As long as it is usesd proper it never can clogg any oil lines or increases wear because of lowering clearances too much (the ceramic particles only have a size of maximum 1 micrometer / 0,001 milimeter). Cera Tec has proven itself worldwide and will protect your engine even under tough operating conditions. The ideal dosage of Cera Tec is at around 6-7% of the total motor oil volume." I pasted in a screenshot of the actual message below. . |
