04-02-2021, 07:42 PM | #1 |
Rep 21
Check Engine Light on "new" CPO M3
3rd day owning a 2018 CPO M3, and the check engine light is on. I drove the recently purchased car from the Ohio dealer to Florida home. Tbh, I was WOT a lot of the way down and hoping I didn't over do it. Very surprised since it's a CPO, stock model. We'll see what dealer says when I take it in....
04-02-2021, 08:03 PM | #3 |
I use my turn signal
707
Rep 278
You have a warranty, a CPO warranty at that. Bring it in and let them fix it. That’s why you paid the extra for CPO.
Loose charge pipe should be an easy fix if it’s that. Last edited by aliiin; 04-02-2021 at 08:19 PM.. |
numbers2017886.00 |
04-02-2021, 08:10 PM | #4 |
Rep 1,977
numbers2017886.00 |
04-02-2021, 09:07 PM | #5 |
Rep 21
Ok, this makes me feel better. Hoping this isn't continual issue. The car did sound like it had a very loud blow off valve...now I know this isn't normal.
04-02-2021, 09:14 PM | #6 | |
Rep 2,640
Congratulations |
04-03-2021, 07:31 AM | #7 | ||
Rep 21
Poiseuille5393.50 |
04-03-2021, 09:49 AM | #8 | ||||||
Rep 2,640
It will be a little tough in the beginning to not engage every yahoo that pulls up on you on the road After awhile it gets easier. Again; congratulations! |
Poiseuille5393.50 |
04-03-2021, 09:56 AM | #9 |
Rep 5,187
You can tighten the crap out of those Norma clamps if you use a hand nut-driver (I don't mean a ratchet). They're top quality and have the little spring shim. I tighten mine till they stop and I see a little pull into the rubber, but I don't crank them.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
Poiseuille5393.50 |
04-03-2021, 11:20 AM | #10 |
Rep 6,732
I would be concerned that the charge pipe clamps were loose. Good thing you have a warranty in case something else goes awry.
Hopefully they either replaced your spark plugs and or charge cooler and just forgot to tighten. Other than swapping out aftermarket chargepipes or replacing them altogether, should be no other main reason to loosen them |
Poiseuille5393.50 |
04-03-2021, 12:14 PM | #11 | |||
Rep 3,737
Drives: 2016 M4 DCT Tanzanite/Amaro
are we enjoying our old friend torque much? welcome to the Forum and best of luck with the car! |
